GT2 RS Clubsport announcement (didn't hear of this last night)
World premiere in Los Angeles
Porsche 911 GT2 RS Clubsport with 700 hp Stuttgart. Near standard and yet spectacular the new Porsche 911 GT2 RS Clubsport celebrated its world premiere at the Los Angeles Auto Show. The 515 kW (700 hp) racing version of the road-legal 911 GT2 RS* sports car is limited to 200 units and can be run at clubsport events as well as selected motorsport meets. For the upcoming years, our customers will not only race the GT2 RS Clubsport on track days but also at international motor racing events. We are currently holding very productive talks with the race organiser SRO, says Dr Frank-Steffen Walliser, Vice President Motorsport and GT Cars. The technology of the race car from Weissach is based on the high-performance 911 GT2 RS sports car, just like in the 935, which Porsche unveiled nine weeks ago. Both share the same engine as their road-legal relative: a state-of-the-art 3.8-litre flat-six twin-turbo motor. Power from the rear engine is transferred via a rigidly mounted seven-speed Porsche dual clutch gearbox (PDK) to the 310-millimetre-wide rear wheels. Like in all other racing versions of the 911, the driver changes gears via ergonomically positioned shift paddles on the steering wheel. The positioning of the engine behind the rear axle ensures excellent traction and braking performances. Six-piston aluminium monobloc racing callipers on the front axle in combination with internally ventilated and grooved steel brake discs with a 390-millimeter diameter provide excellent deceleration values at the front axle. The rear axle is fitted with four-piston callipers and 380-millimeter discs. Like the road-legal 911 GT2 RS, the 1,390-kilogram Clubsport version is equipped with PSM (Porsche Stability Management) including traction control as well as an anti-lock braking system (ABS). Thanks to a so-called map switch positioned on the centre console, these assistance systems can be adjusted separately or switched off completely, depending on the driving situation. The carbon steering wheel and the colour display behind it have been taken from the 2019 Porsche 911 GT3 R model. A massive safety cage combined with a racing bucket seat and a six-point safety harness ensure maximum safety. Air conditioning provides optimal cooling of the interior. The new Porsche 911 GT2 RS Clubsport can be ordered now from 405,000 Euro plus country-specific VAT. Customers will receive their vehicles from May 2019 at exclusive delivery events. Technical description Porsche 911 GT2 RS Clubsport (Type 991, Gen. 2) Concept: Single-seater near-standard non-road-homologated race car Basis: Porsche 911 GT2 RS (991.2) Weight/dimensions: Weight: ca. 1,390 kg Length: 4,743 mm Width: 1,978 mm Total height: 1,359 mm Wheelbase: 2,457 mm Engine: Water-cooled 6-cylinder aluminium twin-turbo rear-mounted boxer engine and rigid suspension; 3,800 cc; stroke 77.5 mm; bore 102 mm; ca. 515 kW (700 hp) 4-valve technology with camshaft adjustment and valve-lift switchoverVario-Cam Plus Electronic engine management (Continental SDI 9) DMSB-approved 100-cell metal catalytic converter Rear silencer with twin tailpipes mounted centrally Transmission: 7-speed PDK gearbox with rigid suspension and short throw Dual mass flywheel Internal pressurised oil lubrication with active oil cooling Limited slip differential optimised for racing Bodywork: Weight-optimised bodyshell in aluminium-steel composite design CFRP motorsport rear wing Enlarged air inlets with integrated LED headlights in 4-point design CFRP roof with removable escape hatch complying with FIA Art. 275a Lightweight CFRP front hood with quick release catches Removable CFRP rear hood with quick release catches 115-litre FT3 safety fuel cell, refuelling through the front hood Welded-in safety cage Recaro racing bucket seat with longitudinal seat adjustment and padding system in accordance with FIA Standard 8862/2009 6-point safety harness Air jack system (three jacks) Fire extinguishing system with electronic release unit Suspension: Front axle: McPherson suspension strut; adjustable height, camber and track, optimised stiffness with high-performance spherical bearings, centre-locking wheel nuts; 3-way racing dampers, reinforced tie-rod; electro-mechanical power steering with variable steering ratio; blade anti-roll bar Rear axle: McPherson multi-link rear axle; adjustable height, camber and track, optimised stiffness with high-performance spherical bearings, centre-locking wheel nuts; 3-way racing dampers, reinforced tie-rod, blade anti-roll bar Brakes: Brake system: Two separate brake circuits for front and rear axles; adjustable via brake balance bar system Front axle: Six-piston aluminium monobloc racing brake callipers with anti-knock-back piston springs; steel brake discs, internally ventilated with 390 mm diameter, racing brake pads, optimised brake cooling ducts Rear axle: Four-piston aluminium monobloc racing brake callipers with anti-knock-back piston springs; steel brake discs, internally ventilated with 380 mm diameter, racing brake pads, optimised brake cooling ducts Electrical system: Instrument cluster consisting of COSWORTH ICD with integrated data logger, sport Chrono watch and boost gauge in a vintage finish Removable Porsche steering wheel with shift paddles PSM (Porsche Stability Management) with ABS, Traction Control and Electronic Stability Control (able to be completely switched off) Centre console with map switch to adjust the ABS, ESC, TC and switch between preset tyre circumferences Porsche Track Precision Race App Integrated lap trigger Lightweight lithium-ion (Li-Fe-Po-) battery, 60 Ah, leakproof, mounted in passenger footwell Emergency cut-off switch in cockpit and outside left of the windscreen Tyre pressure monitoring system (TPMS) Air conditioning Rims/Tyres: Front axle: One-piece light-alloy forged wheels; 10.5J x 18 offset 28 with centre-locking nut; Michelin transport tyres 27/65-R18 Rear axle: One-piece light-alloy forged wheels; 12.5J x 18 offset 46 with centre-locking nut; Michelin transport tyres 31/71-R18 Colour: White water-based paint Vehicle price: 405,000 Euro plus country-specific VAT. Delivery from May 2019 *911 GT2 RS: combined fuel consumption 11.8 l/100 km; CO2 emissions 269 g/km https://cimg0.ibsrv.net/gimg/rennlis...a01eafde01.jpg https://cimg1.ibsrv.net/gimg/rennlis...7bf3ae2d94.jpg |
OMG, finally a proper RS interior!!! Now if only it were a Motec dash and not Cosworth.... https://cimg8.ibsrv.net/gimg/rennlis...4624a9045.jpeg |
just wow!!
Speechless. This thing is just spectacular.
cool. but what does "near-standard" mean in this context?
Here is a car that you could keep in your own garage and self support it at private track days.
You could also do some club racing with lower operating costs then a CUP and ship the car to Austraila or New Zealand for a tarmac rally just for fun! Sexy car. |
Originally Posted by E92 M
(Post 15460573)
Originally Posted by tcsracing1
(Post 15460581)
Same as street car.
I suspect that with the limited production run, (200), chances are that less than 10% of these ever leave their climate controlled garage and of the 5% that do, less than 1% will actually see track time.
(Post 15460576)
I think it is track only device, but I guess could still leave climate controlled garage. More likely to see a Track than 935 shown earlier at RR. |
Cosworth isn't that bad vs Motec...complaints are over rated...but certainly motec would be easier all around.
(Post 15460589)
does that imply that most parts are interchangeable?
go
Originally Posted by TRAKCAR
(Post 15460639)
Nizer and yourself should for sure get a couple each.
Originally Posted by raclaims
(Post 15460672)
