JCR // Titanium & Inconel Valved and Non Valved Side Silencer Bypass (New Product)
JC what am I looking at then on cost for the following?
valved side deletes
silenced center
titanium tips
This is something I would like to try and do myself now that we are in winter. I just want to make sure I don’t have any trouble removing the rear bumper first before ordering.
You can PM if you like.
valved side deletes
silenced center
titanium tips
Basic Sponsor
valved side deletes
silenced center
titanium tips
valved side deletes
silenced center
titanium tips
TITANIUM SILENCED CENTRE BYPASS - £2195.00
TITANIUM & INCONEL VALVED SIDE SILENCER BYPASS - £2695.00
TITANIUM BOLT ON EXHAUST TIPS - £645.00
Minus 5% bundle price
Minus a further 5% on the side silencer bypass until the end of tomorrow
Total - £5123.50 ($6570 USD)
In regards to bumper removal, really quite a straight forward job so I’m sure you would manage that just fine.
Any questions feel free to ask!
JC
Hi JC, In stock form the "exhaust button" seems to do little to control the valves. They seem to automatically close (despite the button bein on or not) and open automatically around 4k. Not sure if the ECU is controlling this. I would like to have it the way it was in my 991.1 c2s with PSE. Valves are wired to the button and you control whether they are opened or closed. How do you guys work around this?
^ contact John at SOUL performance. I just bought a kit from them that allows you to control the valve where it's either open or closed (at the control of a remote fob). The button on the console is no longer functional, but it's supposed to do the job. haven't installed mine yet, but looking forward to it.
Basic Sponsor
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
Basic Sponsor
A little update, we changed up the design a little on our Side Silencer Bypass products in order to add a mounting function.
This uses the same mount system as our Titanium Race Pipe, extra support as per the OEM design, we felt the small weight penalty was worth it. Still comes in at just 0.98kg vs the OEM side silencer at 10.08kg.
Any questions please let me know
JC
JC
JC - what's the point of having the smaller tubes entering the center muffler? With no valves, won't the gasses take the easiest route - via the larger pipes?
Any experience if this solution takes away the 1500-3500rpm drone that the OEM solution gives when running valves always open?
Basic Sponsor
There’s a ton of complex flow dynamics maths to explain however in layman’s when at low RPM the gasses will use both entry points however at higher load the higher velocity exhaust gasses will bypass naturally and take the path of least resistance. It’s this low throttle / low velocity point which reduces drone compared to a single entry
JC
OK, thanks. Can't find them on your website - what do they cost?
@JC, would help if your signature had a link to your site. Also would help if the weight saving was listed (it does for some products, for others it doesn't). Also helps where it says more HP/torque, to state the claimed figures. Of course dyno chart would be very helpful too. :cheers
Everything else being equal (which probably is not in this case) the flow through the 2 pipes should be proportional to the square of their diameters, so some gas should flow through the smaller tube too (yea, caveat lector, little knowledge dangerous and all that...)
^Indeed, as I warned, I am case of little knowledge....
Basic Sponsor
ORDER NOW - JCR TITANIUM SIDE SILENCER BYPASS
Also added links in sig, a bit of an oversight that one! Thanks for pointing out..
JC
All corrected, please find the link below. Products were on the site so hopefully this is working for you.
JC
JC
