GT3 Door Panel Map Pocket Broken - Replace whole Panel at $4k?
I vote for epoxy or JB Weld, depending on what type the plastic is. What's the harm in trying? If it holds, it holds. If not, you still have the $4k option...
They’re still working on it. The argument has been made, by me, that a whole door panel goes way beyond “trim” items.
Im sure it’s a full custom build for a new panel. I have very little alcantara and red deviated stitching.
I havent given up - but if it’s denied, I will definitely try to fix it long before a full replacement.
Thanks to all for the replies - helped with the responses to SA.
Got Porsche to Replace it. They generally agreed that the whole door panel goes beyond "trim." Very excited to not have a home-glued part on the GT3. Would have made it work, but this is much more preferable!! Again - thank you all for the thoughts - helped create a decent argument to get this done.
