Anyone running Dundon headers with center bypass like RSS, GMG?
Anyone running Dundon headers with center bypass like RSS, GMG, GRP? I see most header installs are paired with a center muffler (either stock or Dundon muffler). What are pros and cons? (like drone, etc).
I am thinking about getting headers but already have RSS bypass with stock headers and would rather keep my X pipe. Anyone? Also how bad is the smell with catless Dundon headers?
This mostly for street use and track a few times a year.
I've been thinking of this as well. I have RSS X pipe, too. The route I am considering is to get rid of side mufflers with Dundon headers and lifetime center. I was thinking of headers, side delete and X pipe, but then realized that was a straight exhaust. Neighbors might not like that. I will probably stay with cats. I've driven behind folks with catless and can only take it for so long. No experience what catless smell is like from driver's seat.
From what I understand, there are a number of reasons why one wouldn't want to run Dundon headers, side bypass delete AND rear muffler bypass such as (i) very loud, essentially straight pipe, (ii) loss of torque, particularly down at rpms below 4K, (iii) toms of drone and (iv) won't pass emissions (if your state requires it). For added measure, I don't believe the Dundon street headers would mate with GMG or GRP/BBi rear center bypass as Dundon's attachment points are situated different from the OEM point (which the others use) to allow for the extra length required in their system to meet the power gain goals. Best bet is to get a side delete and put your OEM center muffler back on. This way you get weight reduction (~ 40lbs), less heat around the ignition coil and rear tires and improved sound (over stock) as benefits.
Basic Sponsor
We have had some customers use a center bypass on our headers and side deletes. They were looking for a straight piped solution.
Since our headers and side deletes fit the stock muffler, they in turn must fit with center deletes if the center delete only replaces the center muffler.
Our systems don't fit the side mufflers, those are eliminated.
That said, there are some draw backs:
1. Drone:
3. Loss of torque with center delete
If you're concerned about smell then get our catted headers, very similar power gains, no smell, lighter weight than stock.
When headers and mufflers are purchased together we do offer a discount of $850.00.
1. Drone:
a. Our systems use valves and the longer upper flow path in the stock center muffler to get rid of drone, very similar to the factory system.b. Center deletes use the heavy side mufflers to accomplish this.
2. Loud all the time, as you've discussed the car is essentially straight piped. Some have done this intentionally and loved it. We don't recommend it...3. Loss of torque with center delete
a. When Bank 1 is separated from Bank 2 then there is a loss of scavenging from one bank to the other on the 991.1 due to emissions related exhaust cam timing. on the 991.2 it is likely less of an issue, based on our early dyno results.
We designed our lifetime center muffler to cure the issues of split/broken oem mufflers. Making them from 321 Stainless steel, a full 3" flow path and in 2 version Loud and Quiet to suit most desires. The most popular combination is our Long Tube Street Headers with a Loud Muffler (especially on the 991.2).If you're concerned about smell then get our catted headers, very similar power gains, no smell, lighter weight than stock.
Dundon Motorsports
Gig Harbor, WA
253-200-4454
jamie@dundonmotorsports.com
www.dundonmotorsports.com
Facebook.com/dundonmotorsports
Instagram @dundon_motorsports
Dundon Motorsports
Gig Harbor, WA
253-200-4454
1. Drone:
1. Drone:
Basic Sponsor
The sound is better managed when moving in and out of the valves. Center deletes have a quiet then loud kinda sound. Black Muffler is more seamless, no drone, can be quiet if you keep your right foot tender on the loud pedal...
Catted headers are louder than stock. Best is to go to our blog section of our website and listen to some videos.
https://www.dundonmotorsports.com/bl...rgia-mountains
Catted headers/BlackMuffler will be more edgy a little more raw. Oem muffler is a little more subdued.
Quiet muffler is 10-12dB less than stock
Loud is about 10dB more than stock
Street System is louder than stock headers/cats/side mufflers
Like I said, hard to type what something sounds like...
Jamie
Any group buys? Deals for Canadians with a weak dollar?
Basic Sponsor
I've run group buys in the past with little reward for doing it, chasing people for money etc... ends up being a mess.
How about if I get at least 5 guys to PM me asking for a discount and include "321Stainless" after the 5th guys PM I'll send a code for our web store for 10% off that's good for 2 weeks to all that replied...
Jamie
Jamie
Jamie
Jamie
Basic Sponsor
Maybe we can get another one going in late Feb-March.
Basic Sponsor
Totally understand....maybe my initial question was premature. Guess I'm just excited and have been doing research on exhaust mods. Modded my 997.2 and thought my GT4 could've used some additional sound. So figure I will want something on the GT3 and going with headers, side deletes and lifetime makes sense to me for weight savings, sound and whatever performance gains may result.
Jamie
