PEC Delivery and license plates.
For reference, I did PEC LA delivery in May and they didn’t put any plates on (except PEC plates on the rear) and even omitted the temporary registration sticker on the windshield as per my request (was getting the windshield tinted after delivery). They tend to honor most requests at the PEC, just ask.
Jeahbladejeah (01-07-2020)
I spoke with my SA today. It is correct that as of 1/1/19 in California, the car must leave the dealership with both a front and back license plate with paper tags. The days of having a piece of paper taped to the front windshield will be over. As for how stringent the law is with a screwed in mount versus using a tow hook mount, he was not certain. I told him under no circumstances to drill a plastic plate holder on my front bumper. It could be a deal breaker because I do not want the plates mounted on my front bumper and I do not want to have to buy a new bumper, get it painted PTS and then have a new bumper applied. I am hoping that I can use my tow hook mount to drive it off the lot. The problem will be if I get pulled over and get a fix it ticket for not having a front plate, it sounds like based on the new law, the dealership will be fined. Seems ludicrous to me. How can the dealership control what a customer does with the mounted front plate after he/she drives it off the lot? Even if they do drill holes and mount a bracket, I will remove it. Will keep you posted on what happens upon the arrival of my GT3T in March.
Some follow-up to my prior post. Here is the actual law: https://leginfo.legislature.ca.gov/f...201520160AB516 - section 16 is where the money is for our purposes:
"(a) License plates, including temporary license plates, shall at all times be securely fastened to the vehicle for which they are issued so as to prevent the plates from swinging, shall be mounted in a position so as to be clearly visible, and so that the characters are upright and display from left to right, and shall be maintained in a condition so as to be clearly legible. The rear license plate shall be mounted not less than 12 inches nor more than 60 inches from the ground, and the front license plate shall be mounted not more than 60 inches from the ground, except as follows:"
So...by the letter of the law, a tow hook should be acceptable. Fortunately, the legislature did not mandate a front and center, screw-mounted license plate bracket. They just mandated that the front plate is "securely fastened."
For those of you in the Socialist Republic of California who are buying a luxury car that arrives after 12/31/18, and you do not want holes in your front bumper, I would suggest that you get a tow hook plate holder ASAP. They work great!
Here is an article discussing the law in the LA Times: http://www.latimes.com/local/lanow/l...nap-story.html
Hope this helps!
Hope this helps!
Yeah, I think its going to be mostly about having a readable temp license, somewhere, i.e. the back. CA wants their revenues above all else. I doubt the front plate is going to be a big issue? But I guess we'll find out soon enough.
Fyi, you won't have to buy a new bumper if they drill holes. It should be an easy patch and, honestly, probably a better paint job on the bumper vs. what the factory churns out; PTS or not. But it will be a few bucks.
In CA we had one law that was better than most states and that was the dealer paper plate new vehicle registration. If your car was new looking you could run temp dealer plates. But toll roads were losing money and they paid a legislator to pass this new law. The way the law was written you can actually be charged with a felony if you use fake printed plates, seems a bit harsh.
Holy Guru
Registered Pontiff
Registered Pontiff
The new law is a bummer, but has some reasonable justification. In addition to the tow hook idea, you could print a vinyl plate decal. Some folks also put the plate on their dashboard in a clear case.
Also, you must run your actual state-issued license plate--not a copy or facsimile. 5202 states, in part, "(a) A license plate issued by this state or any other jurisdiction within or without the United States shall be attached upon receipt..." Not only that, but according to 4463, it's a felony (!) to intentionally run a "false, altered, forged, or counterfeited" license plate.
However, the only people who should be worried about the new law are the people who don't run plates at all. If you want to run just a rear plate, everything will be the same. The way I look at it is the occasional fix-it ticket (I get one every few years) is my "No Front Plate Fee"
Any updates? Has anyone taken delivery after the new law? I'm picking my 911T up in April and under no circumstances will I be allowing and drilling of a front license plate on the car. Are they letting people leave with tow hooked plate in the front?
