Orthojoe's GT3RS thread: ED and the end of an era for me
#256
Joe’s track adventures and hands-on experience will be fascinating.
By the time I pick mine up, I’ll know everything there is to know.
Ill try to do a full wrap and see if Manthey ever replies to setup my car as well.
I wonder how much labor it is to install a cage and take it out for shipping to US.
#257
Copying my post in another thread into here to spread the word:
In the GT4, there was a 'high downforce mode' where if you increased the attack angle of the wing, you were supposed to remove 2 small air dams in the front of the car to increase front downforce and balance out the aero. This was described in the GT4 manual
In the 991.2 GT3, the only setting involves the wing and the manual says increasing the rear downforce with the wing may increase understeer. No mention of removing any air dams in the front and, in fact, there are NO removable air dams in the front of the 991.2 GT3
In the 991.2 RS, the manual says the same as the GT3. They only describe adjusting the wing and that you may increase understeer. No mention of removing any air dams. HOWEVER, I have found that in the RS there are indeed front air dams that look identical to the removable air dams in the GT4.
I have removed them with the assumption that if I am adding more rear wing, this needs to be done to balance out the downforce
front air dam
removed
air dam
front air dam
removed
air dam
#259
Originally Posted by hf1
Weird. Judging from this, the helper spring would be fully compressed with the car sitting on the ground. I wonder what the explanation is. I’m assuming they’re using shorter main+helper spring combo on cars with a lift (to allow space for the lift) instead of just compressing the no-lift spring combo more.
#260
So there is no more lines on the shock bottom to interfere with brake pad/rotor exchange work?
What is the speed of the new lift compared to old system?
#261
Originally Posted by Wind911
Excellent photo.
Speed of the lift seems similar. Maybe a touch faster? I can't say for sure
#262
I wonder how does that bellows mechanism raise the car. Does it extend the shock body? Or the shock slides up and down inside the upright?
Also, it looks like there is little room to lower the front further without shorter main springs
#263
I agree there isn't much more room to lower, although the front is already pretty low from the factory. Maybe 1cm lower is all you might consider
#264
#265
front air dam
removed
air dam
front air dam
removed
air dam
#267
This hydraulic designed was first introduced in the '17 991.2 Carrera S/GTS. Here's an image of one that we extracted from a GTS. The hydraulic cylinder slips over the OD(Outside Diameter) for the strut. This one shown in this image doesn't have the threaded gold color tube because it came from a GTS which has non-adjustable fixed ride height. The hydraulic cylinder is the same, even has the bleeder screw for servicing. I think the benefit of this design is that if the hydraulic cylinder needs to be replaced it can be done without having to replace the entire strut. And probably the production cost per unit of the cylinder is reduced since the same hydraulic is used for more applications. Just for clarification, in the image below we added the orange color ring because we converted this lift mechanical to an aftermarket coilover. So, imagine the mechanism in the image without the orange color ring and with a threaded gold color tube.
#268
Very cool, thanks. So the new lift system makes it possible to upgrade the shock and retain the lift function.
#270
It looks very similar to the KW HLS kit, which has been available through aftermarket for a few years. I wonder if this is the same tech since KW has been an OE supplier for dampers.
https://www.kwsuspensions.net/produc...ic_lift_system
