JackPoint Jack Stands Under a GT3
A couple of years ago I bought the Quickjack portable car lift. Gave up on expensive solutions that were not entire solutions. Quickjack is easy to store (lean it against a wall) when not in use and lifts the car about 19-22" at the factory jack points and locks in place making it extremely safe. If you do your own maintenance and/or do track prep in your garage they are the best solution I have found. Some guys take them to the track also.
Quickjack (Bendpak) has recently made some changes to their lineup which has extended the jacking points to ensure that they fit a wider range of cars. The initial models were too short for the modern 911s for example. For the guy who asked about them fitting under a GT3, they sit on the floor in the center of car and you drive over them they are just 3" thick so anything will drive over them on level ground. After driving over them you pull them towards the side and match them to the jacking points, hit the up button and your done. I lean mine against the wall vertically when not in use using a cargo strap and wall anchor then place the pump next too it. Anyone with a garage or storage closet can make it work. Each lift piece weighs 70 lbs and has small wheels on one end so when you stand it up vertically you can maneuver it easily. Best thing to do is measure the jacking points of all of the vehicles you plan on lifting and look at the weights and select what works best for your cars. I have the BL-3500SLX which works great for my M2, I believe it will work on a 991 GT3 also but since I don't have one yet I cannot confirm.
I’m sure that is a great solution, but when comparing to Jackpoints you only need to figure on buying 2 (and two inexpensive standard jack stands). When jacking the rear side jacking point, it raises the front side as well (allowing you to place a conventional stand there)
I'm looking into getting a set of JackPoint stands. Based on photos, do people typically purchase 2? And then get 2 other "standard" stands?
Is there a specific model of Jackpoint I should be looking at? Along with which "puck"?
https://shop.jackpointjackstands.com...ish-JSLPMF.htm
You want the Low Profile Pad:
"The Low Profile pad will not work on pinch welds and is designed for: Porsche 911 - 1987 and later (911 Carrera, 964, 993, 996, 997, 991), Boxster, Cayman, 944. Chevrolet Corvette - C5 and C6. Nissan GTR. BMW 3 series, Audi A6, A7 - (when used with optional Adapters). "
Yes, just need a pair (and a pair of conventional stands). These would work well (out of stock at moment):
Also I would like to use this on my other cars (Accord and Sonata). I assume I can put different pads/pucks on there?
For example this one I grabbed from Google Images looks much higher.
to me it's an issue of availability ..some items show in stock ..some not ...but no reply to any emails I've sent regarding purchasing .....that got me looking at used stands like Daryl has.
This is my issue as well. It has said out of stock for months on their website.
I emailed them just now.
My question is, even if the "correct" ones for the GT3 are backordered, I was under the impression that there are different "pucks" you can get. So can I just buy any of the models and buy the correct puck for my vehicle?
