Warranty implications after Roll Cage installation
Does anyone have experience claiming warranty on a car that had an aftermarket roll cage fitted?
Does the installation void the warranty? Does the warranty apply if it is clear the roll cage isn’t responsible for the issue ?
thanks
thanks
I think they would need to prove that the roll cage caused the issue. You should be fine.
Would you care to give a bit more detail on what you're concerned about?
I mean... the roll cage shouldn't have any bearing on the engine warranty... but if it's poorly fit and wears a hole in your headliner, you'd be hard pressed to get that replaced under warranty.
As mentioned... if it causes the problem... then it wouldn't be covered. But no modifications will invalidate the entire warranty on the car.
I've had rollbars in several cars without warranty issues.
Never an issue with me.
Thanks for your feedback! My fear was that any modification to the car would cause the warranty to be void regardless of whether the cage caused the problem or not. In my experience with insurance co, they try their absolute best not to pay and thought dealers/warranty would be the same.... so I was after first hand experience/horror stories on claiming on warranty after an after market cage was installed.
In Germany, even if you have not used a N-spec tyres, the warranty can be gone as well as approved.
I think we need such a law for consumer rights here.
Since it has been a few months I started this thread, I was curious if anyone has had any issues recently renewing their warranty (might be too soon for .2 but maybe for .1s) or claiming on a warranty despite an after market cage installed in the car? Thank you.
In the USA, the Magnuson-Moss Warranty Act prevents a manufacture from denying a warranty claim unless it can prove the modification caused the defect for which the warranty claim is being made.
Thank you Parkerfe, that sure should give comfort to folks in the US.
So, naturally I wonder if anyone has had issues from installing the cage ? I am focusing more on the type that attaches to the shock towers like the OEM.
What are possible issues the cage could be responsible for ? A Porsche engineer mentioned cracking of the glass due to extra stiffness from the cage (??? I am dubious)
If you can share any real life experiences, I would appreciate.
