Rotor Assemby Hardware Kit: Necessary for Rotor Change?
Location: Chicagoland USA "Turn On, Turn In, Track Out"
1 Post
New rotors are on the way. I came across this on the Suncoast website.
It says that replacing the “nipples“ is recommended with each rotor change. Is that really needed? Mine seem to still be in good shape.
Here’s the part they are referring to. The pic of the rotor is screen shot from a YouTube video for reference; mine have no marks etc.
I bought these as well, and it was part of the service schedule to replace them each time on 997s, but apparently not on 991s. At least I read that on a thread somewhere - supposedly the Suncoast site is wrong in this regard.
On the 997.2’s the nipples are attached to the rotor, so they must be transferred or new installed on the new rotor. On the 991’s the nipples are attacked to the hub and not the rotor. I would just check the nipples and make sure they are no deformed from an ill fitted wheel, replace as needed.
I checked the shop manual sections I pulled and it says to only replace the nipples or bolts on the turbo with center locks. Those cars still attach the wheel guides to the rotors.
"Central bolts (911 Turbo): Use new bolts -1- or five new wheel adapters (depending on condition) -2- .
Replacement wheel adapter (set) contains new screws."
1 Post
