991.1 GT3 RS clear side markers will NOT fit 991.2.
#46
#47
I've swapped out so many of these on my 911s over the years. this current version of 991.2 GT3 RS was by far the most challenging to change. Not sure why, usually its an easy quick job. this time involved a lot of swearing and even cut my finger! again, not sure why
#50
I recently removed the amber bumper lamps from a .2RS and noted this..
#51
Bumping this thread.
The OEM orange side markers sit flush against the fender and black trim. But my clear markers (installed by dealer at purchase) do not. They are countersunk and the transition from the fender, down to the side marker indents. Like the side marker is too small to fill the line between the fender and black trim piece. Is everybody else's like this? The part number on my invoice is 99163125691, which matches what another member said above. But I'm wondering if the dealer used a different part or something. If they normally do not line up flush, then ok.
#55
The ones I ordered from Suncoast sit flush. Same part number as yours.
#56
#59
Wow what bad timing.
I have just replaced my driver side clear marker light for a second year in a row after losing it in turn one at Indy. Suncoast
I have the part number for 991.1 rs if it helps anyone or just a right single for sale if anyone needs one
