View Poll Results: Higher spring rates the right fix for strut tower failures?
Yes
2
15.38%
No
11
84.62%
Voters: 13. You may not vote on this poll
Strut tower failure, higher spring rates the right fix?
do people generally agree the right fix for the front strut tower failures on the 991 GT3 both .1 and .2 is increasing the spring rates?
Platinum Dealership
The strut itself might need more complicated valving to allow it to "vent" excess forces that would smash into the bump stops and therefore transfer into the chassis
Higher spring rates likely help slightly, but maintaining ride height is a bigger factor imho.
And not taking kerbs aggressively on cold tires + low pressure...
Received 5,388 Likes
Are there any parts that can be transferred from the Cup cars or the GT4 race cars to the GT3 to beef-up the tower area?
Other threads on the issue, also from the GT4 board (which shares the same part):
https://rennlist.com/forums/gt4/9483...r-failure.html
https://rennlist.com/forums/991-gt3-...r-failure.html
The best prevention I can see is to a) maintain stock ride height, and b) use a "race weight" lightweight/ 3 piece wheel that will bend on impact to reduce the loads from an impact. The GT3 wheels are significantly stronger than the chassis.
If you were to change something in the suspension it'd be the shock and bump stop (with coilovers). You'd go for more travel and significantly stiffer bump/ jounce damping, especially at high speed. The part that's failing probably has a ~10x factor of safety over design corner weight, so it's rated for the better part of 10k lbs. You only see those types of loads when you run out of travel and metal effectively hits metal.
