.2GT3RS driving impressions vs .1GT3RS
#61
#62
#63
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
#64
Have a look at the g forces measured at HH between MR car on N0 and .2RS on Cup R. The latter clearly generates more grip (in fact more than I achieve in a 996 Cup on slicks, albeit on much narrower rubber). Imv this clearly illustrates that the MR car was on regular rubber and not some special in disguise.
#65
Edit: and there are the .2 gt3 priced at the same rates of .1 rs with some mileage that make this all much harder to pick.
Quite nice options and problems to have.
#66
AC, just out of interest what's the difference between your preferred set up and removing all three mufflers in ur opinion? As it happens this it what I did with my .1 after first putting a SW center delete on but imho I didn't think this made any difference under 4500rpm and so took it off and went for side deletes instead. I was considering the side deletes plus a center straight though delete but just like to get your thoughts on why you kept OEM center instead of removing with sides? Too loud? Thanks, Car looks bloody killer btw.
#67
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,551 Likes
Looks like the .2 definitely had cheater tires, which may have been worth 10+ secs compared to the regular Cup 2 for the ring lap.
#68
The .1GT3RS MSRP was $178,000. The .2GT3RS MSRP $187,000. $9000 Delta. What's to complain about?
#69
#71
Removing all three mufflers and having straight pipes right after the cats was awesome, but brutal. And as much as i loved it, this setup to me is just a little more subdued and livable. I prefer the tone of center stock and side delete over the opposite. so this is what im running now and im pretty sure ill do the same on the next one.
#72
#73
#75
1200 miles on my Mk2 RS now, will be going in for break-in oil change and alignment check soon.
Not sure if my imagination but the steering seems a bit lighter/less feedback on high speed cornering than the Mk1, would need to back to back them to be sure. Perhaps can be resolved with minor alignment adjustment.
