Two GT3's - Best Two Car Enclosed Trailer???
I have a Trailex open trailer and my buddy has a Sundowner open trailer. Hauling two GT3's. We want to look into buying an enclosed trailer that will haul both cars, and give us some room for tools, tires. I have seen the stackers, which look awesome, but I am concerned about height and wind. Also looking at standard 36 to 40 feet normal trailers. Any pro's con's, recommendations? I'll be towing with a 2017 Ford F250. Thanks!
GT3 player par excellence
if you hvae 36' clear floor, it's really too long for bumper pull, do ur. self a favor and do goose neck
for 2 cars with tools, you need 40' clear floor min. otherwise it's very tight.
featherlight
goldrush
ATC
featherlight
goldrush
ATC
InTech or Featherlite. I have both and both are great. If you want a basic all aluminum go featherlite. If you want a super decked out all aluminum trailer go Intech. Mine above is 28ft but long enough for a car and golf cart or car and UTV.
I have a 30' Pace with 29' of clear floor, it would fit two Miatas but not enough room for our BMW endurance car and a Spec Miata. For two GT3s you'll need 36' of floor for just the cars. My 30' Pace is a bumper pull with a 5' RV tongue. Even at this size I wish it was a gooseneck and I pull with a 2015 RAM 3500 Dually.
ATC are really nice trailers.
Ryan
No one seems to be real keen on stackers, is that right?
+1
Ryan
i fit two spec boxsters in one of my trailer with 30' floor, two cars where separated with one foam pad... i was really desperate.
stacker if pulled with regular trucks have longs of wind resistance.
and indeed dually is better but 2500 diesel can handle two car trailer no prob just dont load it up with your entire shop
right on, and it's tight.
If you decide to go with a GN trailer, just remember that you lose approx. 8' of floor when you are looking at sizes, so a 40'GN would have 32' of flat usable floor space for the cars. Like others have said, definitely go with a GN trailer,, with 2 cars, the weight of the trailer and tools it will pull so much better since your truck is a 3/4 ton. Just make sure your pin weight(similar to tongue weight on a bumper pull) on the GN ball doesn't go over your payload capacity of your truck, and you might want to invest in some bags for the rear of the truck to keep things leveled out.
But thanks for all the advice, BIG help.
If you guy gooseneck - I would really consider Intech. I have had 3 of them so far and love them.
You'll need a 42-44' length to pull off the length to do two cars tandem. The stacker height is tough; you'd need 11' height minimum to clear the cars. Unfortunately Intech's stacker lift isn't great.
I'd suggest a tandem pull setup. Keep Ceiling height around 8' and then utilize the bunk for wheel/tool storage. As such you really need a 42' minimum but honestly 44'.
Here's a shot of my 40' Intech:
And this is my 24' bumper pull Intech. I can pull it behind my Range Rover Sport diesel easily:
- Chris.
- Chris.
- Chris.
- Chris.
