Breakdown over 24 second Nurburgring lap improvement 991.1 RS vs 991.2 RS
There was a time when Porsche would lie through their teeth about power ratings (ie 996 GT3 RS). Recently the deltas appear to have shrunk.
TIRES! Porsche had no choice. You can all spend lots of time with all else but you would wasting time. Yes, suspension mods and small HP difference made some difference. Porsche didn’t get result they wanted and the only remaining solution was to have Michelin develop new tires. Put R spec cups on GT3 and you will find same drop in times on PDK-S .2 GT3 vs .1. Funny though....you won’t find them anytime soon until after next gen is released and that’s not accidental, it’s by legal means. You will see significance when someone takes .1 RS and shows what’s possible with new tires. Buckle up for safety!
Driver: - 10 seconds
Drivers get bigger cajones every year.
#Evolution
#Evolution
I reckon the tyres are easily 10 seconds compared to the N0. So the gap does get much more narrow. Can only be proven of course once someone does a back to back comparison, which should not be too difficult to arrange. Also expect the effect of the suspension improvement to be more on GP style tracks that are more technical and less bumpy.
The dark horse in the room is imv the gen2 GT3. If you compare the videos it’s evident that the driver was less committed at places like SX, unlikely because the car could not do it. So on same rubber I think it will be very close to the RS, though probably with less composure.
You'd have thought so but it's in neither the mags nor the manufacturer's interest to do so unfortunately so I doubt it'll ever happen with the likes of SportAuto. I still don't think after taking into account the track/tyre and driver changes (as you say Kluck is quick but with all due respect Estre is going to be a lot faster) the actual chassis/mechanical changes are as much as it is made out to be sometimes. It used to be dropping 5 seconds was a pretty big deal and now people seem to be throwing out multiple seconds on individual changes.
Pure speculation on my part, so curious to start seeing some actual onboards.
But when we head to Spa with drivers of similar ability the differences will be clear. For example the serious drivers all do around 2:40 on N0/1 tyres. The N2 knocks off 1s. The changes to the gen2 will make a significant difference at Spa for a good driver (whilst most likely slowing lesser drivers), so I reckon they will do high 2:36, I.e. about 1s per km faster.
I like this thread here is my thoughts
I'll through out some educated guesses:
Faster track: -2
Faster driver: -5
Weather: -2
Tires, MPSC R: -8 (based on breakdown/ comments here: https://rennlist.com/forums/991-gt3-...l#post15015589)
Revised suspension (also required to make full use of the new tires): -3
Weight (especially wheels): -1
Downforce: -2
Horsepower: -1 (based on lap time vs hp trends)
Faster track: -2
Faster driver: -5
Weather: -2
Downforce: -2
ah didn't realise you and the others had run the N2 at Spa. Ok if it's only 1s there for the N2 then it's a bit less than expected I guess. I'd agree the gen2 will be more difficult to get a good time for most as well. Should be interresting to see anyway when they do come out.
you see the spread of 2 seconds between the (top) drivers set on the same day and consider the 7:20 was done by Timo Kluck (not Glock, the ex F1 driver), who is very good but nowhere near the same level as Estre, I would guess in the region of 5 to 6 seconds. Also, that attempt was never documented, but don’t think Porsche out as much effort into it with the gen1.
I’m now running .2RS spring rates, I could throw a set of N2 on and see what those two factors add up to.
Issue is that the car is setup for 19” now so the car needs to go up quite a bit to fit 20-21” under, ruining the center of gravity again.
Plus rake and camber need to be adjusted again as well.
Its never that easy...
Faster track: -2
Faster driver: -1
Tires, MPSC2 N2: -4
Tires, MPSC R: -7 (based on breakdown/ comments here: https://rennlist.com/forums/991-gt3-...l#post15015589)
Revised suspension (also required to make full use of the new tires): -2.5
Weight (especially wheels): -2
Downforce: -1.5
Horsepower: -3.5 (based on lap time vs hp trends)
Faster track: -2
Faster driver: -1
Tires, MPSC2 N2: -4
Downforce: -1.5
Sweet analysis!
