How do you know when PTS is available again?
Heard that with low chance that PTS might open again.
How do I find out though?
1) Politely bother SA?
2) Check the configurator and see if it's up again?
I like to summon the PTS Wizard. Go to your nearest volcano and throw 3 goats in it, then recite the bible, but in Japanese. Once that's completed you must walk the Mojave desert for 2 weeks and when you emerge create a smoke signal saying "I love Ferdinand" using nothing but natural materials. Then, if its also the summer solstice the PTS Wizard will appear. entice him with cheap scotch and perhaps he can answer your PTS questions.
OK gotta go!
OK gotta go!
How it usually works is you'll ask the SA, he'll say he will look into it and get back to you......then the phone call comes!....he tells you the window is open and you're good to go.....you put your PTS order in and the excitement begins!!!!.....then your SA calls you and tells you the build is on hold an you need to pick a stock color because the window has closed.....or you can try AC's solution which has a similar ending.....
OK gotta go!
OK gotta go!
Can you lose allocation just by applying for PTS?
I meant if applying for PTS for late production vehicle can cause loss of allocation since they won't make any more.
I heard about PTS opening for the .1RS first here on RL...walked into dealer and changed the order. If you wait for the dealer you may never know it's opened up, and it seems to close as mysteriously as it opens.
Just keep reading RL, the folks on here will let you know when the PTS window opens up.
GT3 player par excellence
SA?
sales a**h*le?
most of them know very little other than wiping their a*8
only a few are knowledgeable
so far no PTS for .2RS
sales a**h*le?
