991 GT3 GT3RS and 911R
.2RS Added Brake Cooling = trackable PCCBs?
Old 05-09-2018, 09:53 AM
  #31
CDinSing
CDinSing's Avatar
Thanks for the input. I am trying to decide to option iron or PCCB on the next car. I have AP racing take offs from the GT3 which I would use for track if I went iron or I could sell them and go ST for little more than PCCB. With the ability to resurface once a year, that seems like the best option.
CDinSing is offline
Old 05-09-2018, 11:19 AM
  #32
TRAKCAR
TRAKCAR's Avatar
Love GR / gold! Such a special combo and comes as-is.
TRAKCAR is offline
Old 05-09-2018, 12:13 PM
  #33
mcipseric
mcipseric's Avatar
The PCCBs make the GT3 a different car.
In my experience, straights are 10 - 15 meters longer before the brake zone initiation with PCCBs at speeds around 100 mph and lower.
Something to be keenly aware of when transitioning to steel rotors. Especially back to back sessions in GT3s with different brakes.
I don't have any experience with ST rotors.
First world dilemmas :-)
Have Fun!
mcipseric is offline
Old 05-09-2018, 12:22 PM
  #34
GrantG
GrantG's Avatar
Originally Posted by whatif View Post
Are the OEM calipers identical between iron and PCCB (besides yellow paint)? Only difference being pads and rotors?
OEM calipers are same, except the body of the yellow calipers has a shape that acts similar to an integrated spacer which lets it work with the larger diameter rotors. It is not possible to use the smaller iron rotors with PCCB calipers for this reason, but you can add a spacer to the red calipers to work with larger rotors.
GrantG is online now
Old 05-09-2018, 12:25 PM
  #35
TRAKCAR
TRAKCAR's Avatar
Thanks Grant
TRAKCAR is offline
Old 05-09-2018, 01:52 PM
  #36
usctrojanGT3
usctrojanGT3's Avatar
Originally Posted by TRAKCAR View Post
I went steel to ST.
Same calipers, Easy install, they did mine at the track in a couple hours.
What about brake pads...didn't you have to get different pads for the ST rotors vs. the steel rotors?
usctrojanGT3 is offline
Old 05-09-2018, 01:55 PM
  #37
TRAKCAR
TRAKCAR's Avatar
Not sure about having to change.
i love the RE10 for steel. Pagids were recommended by ST and the combo works crazy good, so I haven’t looked around, 12 track days so far.
TRAKCAR is offline
Old 05-09-2018, 04:16 PM
  #38
whatif
Have Fun!
It's interesting, but I don't know if there's any data to support that PCCBs stop better. In theory the stopping distances should be same for both brakes with the limiting factor being the tires. The iron brakes should be able to provide the same amount of brake torque, just less thermal efficiency. Is it possible that it's the mental factor of you thinking that you have better brakes with PCCBs being more confidence inspiring, so you're more comfortable going deeper into the braking zone?
whatif is offline
Old 05-09-2018, 04:19 PM
  #39
whatif
Never heard cracks matter..
Probably not for performance, just visually. But I guess it's still better than seeing rust on the irons.
whatif is offline
Old 05-09-2018, 04:22 PM
  #40
mcipseric
mcipseric's Avatar
I think you forgot to account for unsprung weight. Faster acceleration, higher straight speeds, lower braking distance with less unsprung weight.
Old 05-09-2018, 04:25 PM
  #41
whatif
Pretty sure the weight is not significant enough to notice differences in acceleration or braking. Certainly not 10-15 meters worth. I would bet that it's the mental factor more than anything else
whatif is offline
Old 05-09-2018, 04:33 PM
  #42
mcipseric
mcipseric's Avatar
1 lbs of unsprung weight is approximately 15.5 lbs of sprung weight. So if we reduce the unsprung weight by 10 lbs per corner = 40 lbs unsprung weight = 620 lbs lighter sprung weight. Much better performance.
Old 05-09-2018, 04:40 PM
  #43
mcipseric
mcipseric's Avatar
I highly recommend going to the nearest Porsche Experience Center and see for yourself. You will learn lots and have a great time!
Old 05-09-2018, 04:42 PM
  #44
whatif
1 lbs of unsprung weight is approximately 18 lbs of sprung weight. So if we reduce the unsprung weight by 10 lbs per corner = 40 lbs unsprung weight = 720 lbs lighter sprung weight. Much better performance.
What are you basing that math on? How is 1lb = 18 lbs of sprung?
I don't have a PhD in physics, but that just doesn't sound right logically. The car weighs around 3100 lbs total. You're telling me that PCCB = 23% weight difference?
If that was the case the lap time difference between iron and PCCBs would be MASSIVE, but it's basically the same (maybe a tiny fraction slower).
whatif is offline
Old 05-09-2018, 04:47 PM
  #45
whatif
I've been to Atlanta -- drove a GT4 with PCCB. Definitely a great time. I also had a .2GT3 with PCCB. But now I'm not so sure about ordering them in the .2 RS since I want to do more track time with it.
whatif is offline
Quick Reply: .2RS Added Brake Cooling = trackable PCCBs?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
