BBi Autosport 2018 Spring Sale on Porsche 991 GT3/RS Exhaust, Roll Bar, Suspension
Basic Sponsor
Track season has already started!!! Enter coupon code BBiSpring2018 at time of checkout online to take advantage of our Spring Sale and save 10% off selected products. Offer is also valid through our participating authorized dealers. Here are the BBi Porsche 991 GT3 upgrades that will be on sale:
BBi Autosport StreetCup II Bolt-In Roll Bar Porsche 991 GT3
Features
BBi Sub-Belt Mount Porsche 991 GT3/ GT3RS / Cayman GT4
Features
BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat
The BBi Autosport race spec seat mounts are a direct bolt in to the factory mount location for a hassle free, easy installation for your competition race seat. The BBi Autosport Seat mounts have a large range of adjustment options allowing fitment for all major FIA and SFI approved seat brands and offers an integrated 5 and 6 point sub belt mounting location.The wide range of adjustment covers almost all possible seating preferences to properly seat drivers of all sizes. CAD designed, CNC laser cut and formed from one piece of .125” (1/8”) carbon steel with no welds to maximize strength and stiffness. All mounts are powdercoated with a wrinkle black base and satin black sides.
Features
BBi Autosport StreetCup Exhaust Bypass Porsche 991 GT3 / GT3RS
Features
BBi Autosport Porsche 997 & 991 GT3 / GT3RS StreetCup Center Section Exhaust
Key Features
Product Linkhttps://www.bbiautosport.com/product...ry=991.1%20GT3
BBi Autosport Street Cup Suspension Package Porsche 991 GT3/RS
The BBi Street Cup Suspension Package improves the handling response of the vehicle by upgrading the factory springs with an improved linear rate springs and replacing the factory arms and links with the motorsport Cup version that uses spherical bearings.
Complete Package Includes:
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on front and rear sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
Features
- Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
- Precision CNC laser cut and bent from one piece high carbon steel for superior strength
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- Attaches to seat assembly using factory mounting points with all hardware included
- Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
- Made in the USA
Features
- Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
- Multi way adjustability
- High strength sliders, mounts to base with 4 bolts per slider
- Integrated 5 and 6 point sub belt mounting locations
- No modifications to vehicle or any seat mount components are required for installation
- Uniquely designed for Porsche vehicles for the best possible fitment
- Mounts to factory bolt locations with precise factory fitment
- Fits all major FIA/SFI approved seats up to 17”
- 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
- 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
Features
- Delivers deep aggressive exhaust sound
- Significant weight reduction of 40 pounds
- 304 stainless steel aerospace tubing
- Meticulously TIG welded
- Brushed stainless finish
- Stainless hardware and clamps
- 100% emissions legal
- Will not void warranty
- Factory secondary mufflers and catalytic converters are all retained
- 50 state emission compliant
- Direct bolt on replacement
- Compatible with 991 GT3 and 991 GT3RS models
- Made in USA
Key Features
- Retains Sport Exhaust Button function
- TIG welded T304 brushed stainless steel construction
- Factory primarly side mufflers & catalytic converters are all retained
- Fits all 997 & 991 GT3/GT3RS models
- 50 State 100% emissions legal
- Optional black ceramic coat finish available
- Made in USA
- 2 Coilover Spring (Front)
- 2 Coilover Spring (Rear)
- 2 Coilover Helper Spring (Front)
- 2 Coilover Helper Spring (Rear)
- 2 Billet Monoball Lower Trailing Arm
- 2 Billet Monoball Upper Trailing Arm
- 2 Billet Monoball Upper Wishbone
- 2 Monoball Front Bearing Flange
- 2 Monoball Rear Bearing Flange
- 2 Upper Spring Rest
- 2 Lower Spring Rest
- 2 Adjustable Sway Bar End Link Front
- 2 Adjustable Sway Bar End Link Rear
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
Basic Sponsor
