Break in Fallacy?
Break in Fallacy?
So the dealer and the GT mechanic both said "you don't need a break in period with this GT3".....to drive it and not worry about the rpm's.......who else was told this? I'd prefer to go by the book, if there is a book........(tried to post similar earlier but don't think it worked)
I can live with that, sounds reasonable.
If I remember correctly the European versions do not recommend/require a break in period - anyone wish to confirm or flame me to correct this?
I was at PSDS a couple weeks ago - great fleet of P-cars they have you drive, all new - I think the most miles on any of the cars I drove was ~2K miles
i asked one of the instructors about "break in" - they said no need...
meh, who knows?
meh, who knows?
^ I believe you are correct. They just do not mention break-in where as they do in the States. Could have to do with the Lawyers ect here in the States.
Break-in has much to do with the tires, brakes and other things as it has to do with engine. A new set of tires can be very slick.
Ran with a guy at Lime Rock with a new .2 GT3 (PDK) and asked him about his break-in process. He said he's had multiple GT Porsches and his break-in process consisted of going through TWO full tanks of gas and then done! Never had an issue...
Warm up carefully - cool down carefully. The first time and every time.
Staying 1000RPM under the limiter for 500 miles cant hurt.
I didn't quite make it to 500 miles, but @ 27,000 miles, it has stopped using oil and runs fine.
All oil analysis reports are OK.
Just add spark plugs every 4-6000 miles - 12,000 miles is too much.
All mileage +/- 50% Track miles.
Just my 0.02C feed back.
Given that brakes, suspension, transmission and engine are all new and working together for the first time it probably makes sense to do a gradual break in. I drove mine like a baby for the first 500 miles and then stepped things up a bit every 100 miles. I also changed the oil at 1000 miles just because always do this on my new cars. I am now at 1600 miles and have recently begun to let her rip. Adding a new center exhaust tomorrow to ensure the car sounds as good as it drives.
I don't know what it says in the 991.2 GT3 UK manual, but here's the break-in section from the 991.1 version.
UK 991.1 GT3 owners Manual
Last edited by alpine-al; 04-11-2018 at 10:38 PM. Reason: I inserted the wrong excerpt. This is now the UK version
I know this topic has been covered numerous times, and people have heard different things.
For reference/perspective:
1. At PEC LA and Atlanta, all GT3, GT3 RS go through a 1500 mile break in period. The instructors were instructed by the headquarters to require the complete break in period before letting the first customers drive it. Since PEC cars are not registered for road, they can only put on the miles inside the facility on the circuit. Instructors rotate through "on duty" hours everyday to put on the miles, it takes over a week to put the miles on one GT car, this is why sometimes it takes awhile for new GT cars to be available for normal consumers to "experience" after it had landed. I was the first to drive a particular GT3 at PEC and it had right over 1500 miles. Although sometimes they do get it out a little early due to prior scheduling, delays and etc.
2. At factory tour in Germany, I asked couple engineers about this, and they suggested that the way the engine is built on the 4.0 engine, it is much more important to do the proper break in on this particular engine than the normal engines (3.8, 3.0 etc). They suggest me to do it.
Just what I've seen and heard but you should decide for yourself
^hey there some valuable info , nice .
I respected break in , always warm up oil , never drove in pdk auto ,( thing skips up thru the gears lugging ), didn't run up over 7k rpm's till 2k on the O
and only briefly over 5k rpm in first 1k
just did 24k dealer service which was oil change # 7 all oil samples similar and good, very low ppm particulates .
motor very strong and seems freer spinning up
So, you mean the new 4.0 with the differences from the old 991.1RS 4.0 wants perhaps a little more break in?
Since the financial onus for repairs is on Porsche for the first four years, what do you expect them to say? Generally Porsche GT cars are not DD cars. To wait 2000 miles (for me about six months) before experiencing what you paid for seems a little excessive to me.
2 tanks of gas and you are good to go.
As per GT3 CUP mechanic.
