991 GT3, GT3RS, GT2RS and 911R 2012-2019
Musicar Stage III Audio Upgrade - 991 Porsche GT3RS
Old 04-04-2018, 11:20 PM
12v Nick
Platinum Sponsor
12v Nick's Avatar
Default Musicar Stage III Audio Upgrade - 991 Porsche GT3RS
Today we had the pleasure of installing one of our Musicar Stage III Performance Audio Systems into this beautiful 2016 991.1 GT3RS. The owner complained that the engine and exhaust sounded great, but the sound system was far from a compliment to that, especially for his longer road trips. We exchanged a few emails and decided that he would drive down to Portland, OR from Seattle, WA to have us personally install the whole kit.
For those that aren't familiar with our outfit, we have three stages of performance audio upgrades that are specifically tailored to the pre-facelift 991/981 chassis cars with the Sound Package Plus factory system(almost every GT car). For more info on the stages, check out this thread on the whole kit structure and this one the Stage I tweeter upgrade. For this project, we needed to have enough power to overcome the engine and road noise and the right speakers to give us the clarity and dynamics at those volume levels – Stage III was the logical choice. Here are the components for that setup:
  • Musicar 28mm High-End Tweeters (Dynaudio of Denmark)
  • Musicar 100mm High-End Midrange (Dynaudio of Denmark)
  • Musicar 230mm High-Output Woofers (Morel of Israel)
  • Musicar Performance DSP Amplifier (Mosconi of Italy)
  • Musicar Plug and Play Input/Output Harnessing (Musicar Northwest)
Our goal is to utilize some of the best equipment available and adapt those products to fit the Porsche platform perfectly. The speakers and amplifier are 100% plug and play and bolt-in using all of the original hardware. Not a single wire needs to be cut nor any holes drilled. In the end, it's also 100% hidden. The new amplifier will live in the same cavity under the passenger seat as the original amplifier and all of the speakers utilize factory locations. We even use an amplifier with a built-in sound processor that we've spent countless hours tuning to the cabin of these cars. We're going for great sound here, and that doesn't need to be seen!
Here are some photos of the components after our modifications/preparation:
We've got more photos of the installation process itself, but I'm still taking them off the camera and editing them, so stay tuned for more soon!
–Nick
mcomet (01-13-2020)
Old 04-04-2018, 11:57 PM
binky
binky's Avatar
What is the cost of a stage 3 setup for this car?
Old 04-05-2018, 01:45 PM
12v Nick
Platinum Sponsor
12v Nick's Avatar
PM'd
Old 04-05-2018, 01:58 PM
smbryan
smbryan's Avatar
Before and after videos showcasing the audio difference(s) would really help...
Old 04-05-2018, 02:24 PM
12v Nick
Platinum Sponsor
12v Nick's Avatar
That's a tough one – these systems are so resolute and impactful that a video would likely show you that there's a big difference, but wouldn't give you anywhere close to the actual sonic improvements. If I'm not mistaken, the owner is a fellow forum member, so we might be able to get him to chime in on his personal experience! We've got a number of these kits in the wild at this point, so there are some other sources for a non-biased opinion.
Old 04-05-2018, 05:39 PM
drdonger
drdonger's Avatar
More details please!. How many watts are going to the speakers each? How many channels is the amp? Passive or active xovers, active I'm assuming? What is the weight of the overall system? Can this upgrade be done for Bose systems or .2 cars? Thanks in advance.
Old 04-05-2018, 06:46 PM
Jamie140
Jamie140's Avatar
Do you have a 981 boxster spyder solution?
Old 04-05-2018, 07:22 PM
Psup4s
Psup4s's Avatar
Those are some great looking drivers. Dynaudio and Morel are top shelf. Can you pm price for this set up...minus install.
Old 04-05-2018, 07:59 PM
NVRANUF
NVRANUF's Avatar
I just re-installed your 28mm Tweeters in my GT3 Touring. Originally from my 991.2 TTS.
Curious about the rest.
PM details please.
Old 04-05-2018, 08:04 PM
12v Nick
Platinum Sponsor
12v Nick's Avatar
Happy to share the tech details. I forget sometimes that we're not the only one that like to "nerd out" on that stuff! The amplifier is actually an 8-Channel Class-A/B design with a built in sound processor – the combination of analog amplification with digital processing is a phenomenal pairing. When we use that amplifier in this particular setup, we set it to a staggered 6-Channel mode that feeds 60w to each tweeter, 60w to each midrange, and 150w to each woofer. This is what we call an "active" system since every speaker in the setup has it's own discreet amplifier and processor channel. That approach allows us to independently tune each speaker with equalization, time correction, and phase – invaluable tools when we're working in automotive acoustics.
The weight change of the system is approximately 25lbs additional including the new speakers, amplifier, and sound treatment. Not enough to make a difference in your weekend track days. It's not available for Bose or Burmester cars built before 2017, but will soon be available for any 2017+ platform with PCM4.0+ equipped. R&D is going on right now so we'll probably be supporting that change in 30-90 days. For right now, it's specifically designed for 991.1 or 981 cars with Sound Package Plus.
If it has Sound Package Plus, then absolutely. We're building a Stage III system right now for a GT4 owner.
Thanks – PM on the way!
Old 04-05-2018, 08:11 PM
NVRANUF
NVRANUF's Avatar
It's not available for 991.2 Bose GT3s? Bummer!!
Old 04-05-2018, 08:23 PM
12v Nick
Platinum Sponsor
12v Nick's Avatar
Not right now, but hopefully soon. We're just days away from receiving our first beta audio integration module for the 991.2 with Bose. If that works as hoped, we'll just need to finish development on the mounting and wiring harness and it's ready to rock-n-roll. I'll keep you in the loop!
Nick
Old 04-06-2018, 12:19 AM
CAlexio
CAlexio's Avatar
Received 1,963 Likes on 915 Posts
Nick
For those of us with Bose will it still be as big of an overhaul or will some components be retained?
Old 04-06-2018, 02:36 AM
qbix
qbix's Avatar
What’s the point of installing all that stuff if you don’t have a proper sound insulation on a GT3 car?
Old 04-06-2018, 02:48 AM
OldGuy
OldGuy's Avatar
Damn and I thought WE were the drivers!!
M Coop (11-09-2019)
Quick Reply: Musicar Stage III Audio Upgrade - 991 Porsche GT3RS
