ABS can't be switched off on 991.2 GT3???
Platinum Dealership
cup cars do not come with ABS and therefore destroy a lot of tires during the adjustment process. of course customers tend to destroy cars when they get it wrong also.
the reason cup cars can manage without ABS...adjustable brake bias. so you can manually, while on the straightaway, adjust more rear or front depending on which type of feel you want. The more front you dial in, the more lockup will occur which is really counterintuitive but that's reality.
Also- OP: you cannot threshold brake and have microlocking on regular *** tires. that only works on slicks or in the dirt in a modern car.
Originally Posted by _fletch
Oh wow sorry for my ignorance here - I haven't actually bought a new car for nearly 20 years as I've been living in London and NYC, and I've been used to driving race cars.
This really sucks big time. Can a fuse be pulled to disable it? If so anyone have any experience with this in a GT car?
Again sorry for being late to the game here, but this is super important to me.
OP, why not simply learn to drive a modern high performance car or conversely, you can look to buy a non-ABS Carrera 3.2 or buy an early model 964 and go full track prep.
You might want to check out the Glickenhaus SCG 004S https://www.carmagazine.co.uk/car-ne...res-and-specs/
If you look to the right of the steering wheel you can see a ON/OFF switch for the ABS
Just make sure you let everyone else know what set-up you are running (ABS-less) on track days.
... so everyone can give you 300m buffer...
Having steering wheel working the opposite way is also challenging! I tried that on a bicycle. Was even offered 100$ if I can go 5 meters :-) (but paid 20 to take that offer).
I remember during drift-days that at some cars when you are spinning - the brake pedal is stiff (no braking - even if you press the pedal maximum). Meaning no braking possible based on electronics - during reverse sliding or / spinning. This can cause problems.
Don´t know how it works with the 991 - as long i never spun one.
Not a dumb question. For me braking is the single most important and challenging aspect of circuit racing as well as the most enjoyable. I'm by no means a great driver but I've worked hard at my technique and it's one of the few areas I can beat other 3rd-rate drivers like myself. I won't be racing this car but I do want to at least track it occasionally so not being able to fully use one of the few skills I'm actually half-decent at and enjoy the most will be really disappointing.
