Because PDK: Some observations after a roll race
#61
And other people have driven MT's for decades, are proficient with them and don't "need" a PDK gearbox yet think that it is a better match for the 991 variant of the GT3 than a manual. You may try to paint everyone who prefers PDK in this application as "Rick Bobby", but it's an inaccurate characterization. Peace out.
And I agree as well that if your goal is to coax that last couple tenths out, then PDK is the proper tool. But propagating inaccuracies like the OP is doing about PDK being massively faster than the manual is likely to encourage more people like me, that are more about driving curvies or enjoying the car as a daily driver with only rare track use, to buy the PDK and hate it like I did and do.
#63
Every driver is different, so of course it doesn’t apply to everyone, but we all agree they’re out there.
I know you are but what am I...... Lol
#64
As far as propagating inaccuracies, I shared an experience. A buddy of mine in a modded GT4 raced a .2 GT3 owner (who is an excellent driver with way more track experience that most of the guys here have) to a draw up to about 100 mph. I raced the same GT4 and walked away from him multiple times. What does that mean? I don't know. But it is a data point that needs to be confirmed, which I said we would try to do. Not sure what else to tell you. It isn't like I made it up. Besides, the 0-60 times favor the .1 GT3 over the .2 MT. The 1/4 mile times favor the .1 GT3 over the .2 MT. Not sure what to say other than we will try to confirm it on the track, at which point everyone will say those results don't matter because the PDK has the advantage with LC.
Just sharing an experience!
#65
Originally Posted by SCCAForums
Sorry, your buddy needs to learn how to 'shift'... here's my .2 GT3 6spd vs. a new '18 Turbo S.. from a roll... no way a GT4 plays with this crowd from a roll:
https://youtu.be/2nlH8qkgMtw
Best Regards,
Dave
Best Regards,
Dave
#66
It looks like the manual .2 GT3 is putting down more power. Either way the .2 GT3 is about 10 car lengths faster than the .1. I highly doubt the GT4 can come close. If you .1 pulls away steadily and the .2 GT3 can pull away steadily from a .1. Then the .2 GT3 would run away from a GT4.
#67
https://www.youtube.com/watch?time_c...&v=9ojd4BrHZS0
#68
Since the average 1/4 mile or roll-race is not going to include speeds above 150 mph, the better gearing of PDK is not going to come into play much.
#69
Hi Rob - that would be a big advantage for the PDK (nearly 6%), if the individual gear ratios (1st through 6th or 7th) were identical between Manual and PDK. But they're not. To get the overall gear ratio, you need to multiply the ratio of the individual gear and the Final drive. Once you do that, you'll see that the Manual and PDK have very similar ratios in 1st through 4th gears (within a couple/few %), but then PDK enjoys a larger benefit in gears 5th, 6th and 7th (5th doesn't happen until very high speeds if you drive Manual to redline in 4th - probably ~150mph).
#70
Grant, I was looking at this article, among others.
https://www.roadandtrack.com/car-cul...ing-explained/
Somebody had posted this up (you were in that thread too)...
991.2 GT3 Gear Ratios (according to Accel Junky)
1st Gear 3.75
2nd Gear 2.381
3rd Gear 1.72
4th Gear 1.344
5th Gear 1.081
6th Gear 0.881
Final Drive 3.091 (Constant 1.216 from Porsche http://press.porsche.com/newyorkauto...ifications.pdf)
The gear ratios are essentially the same for the 997 GT3 RS and the 991.2 GT3/911R. What I think is different here is the listing of constant on the final drive ratio of the 911R. This I believe is an idler gear or drop gear configuration on the final drive. So the effective ratio of the final drive is figured by multiplying the listed ratio by the constant ratio.
3.091 x 1.216 = 3.757 Final Drive
The PDK had...
First Gear Ratio: 3.75
Second Gear Ratio: 2.38
Third Gear Ratio: 1.72
Fourth Gear Ratio: 1.34
Fifth Gear Ratio: 1.11
Sixth Gear Ratio: 0.96
Seventh Gear Ratio: 0.84
Final Drive Axle Ratio: 3.97
What am I missing buddy?
1st Gear 3.75
2nd Gear 2.381
3rd Gear 1.72
4th Gear 1.344
5th Gear 1.081
6th Gear 0.881
The PDK had...
#71
#72
Yes, changing the Final Drive of a particular car to be lower will have some desirable effects wrt acceleration. But comparing the Final Drive of two cars with dissimilar gear ratios has no meaning without also considering the individual gear ratios as well - just as comparing the individual gear ratios of two cars is meaningless without considering the final drive or tire diameters...
#73
1st Gear 3.75
2nd Gear 2.381
3rd Gear 1.72
4th Gear 1.344
5th Gear 1.081
6th Gear 0.881
The PDK had...
1st Gear 3.75
2nd Gear 2.381
3rd Gear 1.72
4th Gear 1.344
5th Gear 1.081
6th Gear 0.881
The PDK had...
#74
OK, this is much more useful data (you added additional stuff after my first reply). If correct, it implies a gearing advantage for the PDK of 5.67%. However, I think I have seen different numbers before that implied a much smaller gap. If I can find it, I'll post here. Happy to have the conversation
#75
I looked through my old gearing spreadsheets and found a variety of different numbers for the Manual's Final Drive. Hopefully, someone will chime in with a confirmation of the exact number. Anyway, here is a chart for PDK first:
