Any aesthetic car care DIY requests?
#76
I have a question for you, and I would appreciate any advice. On my white .1 GT3 I used M105 and Jescar with a microfiber pad on my hood, and the minor imperfections (almost look like little hairs - not swirls) are gone now. But I still see small little pin ***** marks (even high on the hood) that you can't feel with the touch, so I am not sure if these should come out with more effort or not. I don't want to go too far on the clear coat, but at the same time I am not sure if I am going far enough. On the rest of the car I generally only see these tiny hairs (almost like lint) that buff out with a few passes. White cars hide so much. :-)
How would you know if you could go farther or not? Paint depth gauge?
Thanks for the help!
#77
#79
[QUOTE=Detailed Designs;15463370]
The least intrusive and most (immediately) cost effective thing is to apply a carnauba wax or synthetic polymer via a dual-action machine. Those products will artificially fill much of those microscopic voids/scratches that are causing the light refraction(what you see as "swirls").
Hope this helps shed some light on the topic for you. If you'd like a referral, I have a few people I'd trust in Florida. Just ask.
thanks for this info. I needed to get something done, so I went with a paint sealant. I had the carnuba wax, but took it back in favor of the sealant based on comments read here. I must have had the microscopic scratches as it looks pretty darn clear now, and I don't see the swirl marks anymore. Of course, an expert eye may be able to point out some issue to me. Glad I did not go with the glaze in case I do decide to go with correction and then some sort of correction and film.
Sure, who do you know in FL? I'm in St. Augustine area.
#80
[QUOTE=Madisongy;15606157]
The closest I can speak of at the moment is Karim Fritz of https://superiordetailer.com/. But he is in the Orlando area.
#81
#84
Any recommendations or power steamer for cleaner, I don’t need to wash the car much as I drive in fair weather only and was thinking a quality pressure steamer would be better than a pressure washer, thoughts?
#86
Dear JC - What do you recommend for removing winter salt from my carpets? Have Weathertech inserts but ended up collecting a lot of salt around the gas pedal. Thanks
#87
I feel very foolish for asking as NO one is too eat in my cars.... i dropped a hot cheese tac- o sauce on to black leather perforated seats ( ones that have A/C) can't get out... thoughts?
#89
Wet Vacuum system like Zero Res for carpets. If that doesn't work, burn it and get the insurance and go get a new one.
