.2GT3 gas gauge
so I had to replace my fuel gauge under warranty at 6k on my .1GT3 and now my .2 is showing tank after a 100 miles of travel so might have a bad gauge. Anyone else having any gauge issues? |
If you have the extended range fuel tank and you have a full tank it the needle doesn't move until you get to about 13 gallons. It will show full. This is how it was on .1 and .2....
Ok, I do have extended range tank and that might be it. Will put another 50 miles on it and see if it moves. Thanks for info |
Originally Posted by Scott_997
(Post 14742606)
Had the same problem on my .2 would register empty w a range of 0 miles , I ran it for about 250-300 miles then filled up it started working fine since |
I thought the same thing about my .2 with extended range tank. Needle never budged off full over the first 100 or so miles. Thought I may have an issue with the gauge, but it did finally start to come off the full mark with some further driving. |
I went over 150 miles before it moved. (large tank)
Same here, needle doesn’t move until 100 miles or so of driving (10-13 gallons I think) |
