Noob Headlight Question
Seems like headlights are really confusing. Been searching threads but a lot of the info is for other cars or older GT3 models and I'd just like to confirm.
In what configuration are the lower light bars in the bumper on? Are they part of DRL? Are they part of the low beams? Can they be turned on/off independently of the other lights?
Standard bi-xenon DRL = 4 tight LED dots + lower lights in bumper?
Bi-xenon + PDLS DRL = 4 tight LED dots + lower lights in bumper?
LED = 4 wider dots + ring and the lower lights in bumper are not on for DRL?
Or do I have it backward?
With respect to non-LED, if we're talking .1 GT3, the bumper lights were DRL since the headlight did not have the 4 dots (I believe for both std light and PDLS). For .2 GT3 non-LED the headlight now has the 4 dot DRL so I don't believe the lights in the bumper come on.
The above is correct for LED - bumper lights are NOT on for DRL as the LED ring is the DRL. This is true for .1 and .2 GT3.
So I'm confused.
In both photos above it looks like the parking lamps (running lights) are also on so it’s not really a true DRL scenario right? Note that that side markers are on and pretty sure taillights are lit too. You need a photo in daytime in actual DRL scenario. I’m guessing the bumper lights come on when the running lights come on. My car has LED’s otherwise I would check.
I was under the impression that for daytime running lights, non-LED get the 4-dots in the headlights and bumper lights, and LED only get the halo DRL, not bumper lights. Could be mistaken
I have LED. You get the 4 LEDs in the halo as well as the halo which you can see up close. No bumper lights. If you turn on your "first level" lights, then halo/LEDs go away and the bumper lights come on only. For non-LED, you get the 4 inside running lights as well as the bumper lights.
Guys, look at the photos. The bumper lights are on and the DRL are also on. Simultaneously. I have an entire folder of GT3 photos on my computer and plenty of additional examples. Shamoo, you're saying that on your car you can't get the DRL and bumper lights to be on at the same time?
DRL and turning the headlight/bumper lights on (or if on auto at nighttime) are two entirely separate things. DRL are on ALL the time as soon as the car is on. Even in bright sunlight during the day. You can get the bumper lights and headlights on if you turn the lights on manually or at night time if the lights are set to auto....
After all this I'm still a bit confused as to what the point of the bumper lights are with the LED's. Sure... you CAN turn them on but what are they for? The dots and halo are the DRL's and the main beams are the main beams. Why have the bumper lights at all? Are they just vestigial lights from the base 911's that didn't used to have the 4-dot DRL's?
