Basic Track Setup Guidance 991.1 GT3
Thanks Chris. It's a 991.1 that I've been tracking some (5 days). I was going back and forth on whether to to get more serious about making it more track worthy. After last weekend at Sebring, I finally decided I was crazy not to spend more time at the track in this car. It's just sublime, but also very fast. I've got 20 years of experience, and even though it is very easy to drive, this car is too fast for 3 point belts.
Kind regards,
Chris.
Former Vendor
Why thank you Chris, I appreciate you saying so : )
Nice to find another local! We know the 991 GT3's very well and Sebring is our home track, we are there most every event and run the Suncoast DE events. Give me a shout at 484 883 6197. We'll chat about your car a bit, and we can dial it in with our tailored chassis setups for Sebring. We also have harnesses and roll bars in stock for the 991 GT3, and would be more than happy to do the install. You can replace cars, you can't replace people. We also support all our guys at the events we go to so you can pit with us, we'd love to have you
Former Vendor
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,792 Likes
Use factory alignment, messing with it doesn't help much in this car, and changes could make it worse. Use Cup 2 tires, around 32 psi hot. Cantrell is a good roll bar.
With the multilink setup (and maybe RWS), I can see how negative camber might be less important in the rear, but how is it possible it wouldn't help in the front? I find that hard to believe, but I'm old enough to know there's a big difference between theory and data... Any data on stock vs. max camber alignment head to head?
Anyone have head to head data with and without a DSC controller for PASM? Does it help?
Lots of track guys played around with the setup of the car during the first year or two after it came out, and experienced showed that there wasn't much or anything to be gained by messing with the setup; a possible exception is a setup with big cambers and other changes, but that setup isn't practical on the road. A pro shop I've worked with also told me that they spent a lot of time working on the setup, and concluded that not much can be done to improve on the factory setup (owner of the shop is a pro racer who owned the car himself).
With the suspension setup and PASM, the car doesn't roll much in cornering and there isn't much camber change. Apparently, the factory camber of 1.5 to 2 degrees is enough to make proper used of the tread in cornering, and keep in mind that the sticky rubber of the Cup 2 is in outer third of the tread. Too much camber or tire pressure will move the contact patch away from the sticky rubber, and could also adversely impact braking, as well as the transition from braking to cornering.
How can an enterprising entrepreneur make a small fortune in racing?
Basic Sponsor
Forgeline, as mentioned above, is a great choice. If you want the best and spare no expense then the HRE R101 Lightweights are the ones you should be after. They save 30+ lbs over the factory wheels and come in any color you desired. Not to mention they are beautiful to look at:
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest Dealer In The World for HRE Wheels, ANRKY Wheels, Vorsteiner Wheels & Aero, Akrapovic Exhaust, & iPE Exhaust
BBS, Forgeline, & TechArt Premium Dealer
Brembo / Rotiform / KW / H&R / Novitec / Brabus / Mansory and tons more...
But won't the crazy castor angle required for more camber fix the braking?
Makes sense. Thank you. Sounds like it's not worth it unless you move to Hoosiers or similar, which tend to appreciate more camber. Plus more grip = More Gs = more roll = more negative camber = stiffer springs = more $$$
If you go to Hoosiers or slicks, the higher grip could necessitate numerous changes, as you note. But keep in mind that doing that could also void the warranty, and the 991.1 has the extended warranty for the engine. Some have argued that the Hoosier is a DOT R-comp tire like the Cup 2, but it surely has more grip, and the car does have a G-meter.
Basic Sponsor
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
sales@gmgracing.com
www.gmgracing.com
714.432.1582
I took there advice and used a -1.5 camber from and rear and it's working...no tire issues at all pretty even wear. I am running 34psi front and 36 psi rear. My rear will shoot up to 38psi but still no much of a problem just a little looser rear.
Michelin highly recommends hot pressures from 34-38 front to rear depends on car, alignment and track. They also say DO NOT go out under 26 psi....keep psi higher and bleed. I see guys chunking MPSC2 tires and Michelin was asked about this and its because of too low psi.
My starting pressure means that I'll be way above 32 by the end of the first session, but I just continue to bleed off through the day as needed.
I understand and appreciate the advice to keep the alignment stock, but just for giggles does anyone have direct experience with the wear patterns when running more camber with MPSC2s? My experience is that I've got -2.2 up front and show clear additional temperature deforming wear towards the outer edge of the shoulders (actually front and rear). Starting pressure of ~28psi, hot pressure of about 35-36 or so.
