.2 GT3 - Oil Overfill Warning came on AFTER driving car for a month
#31
A huge puff of smoke? I guess the new rings in the .2 i heard about didnt solve that issue. Oh well, character lol.
#32
After a drive I normally let the engine idle for a while before turning it off. Even on my .1 GT3 and 991RS it more often than not resulted in the next cold start being smokeless. It’s worked on the .2 GT3 as well. The last time I started it was to take the car outside for a quick icy photo and then a quick tuck away back in the garage. I didn’t follow my idle down process. Maybe thats why the puff of smoke. Ah well... I’m happy for it
#34
After a drive I normally let the engine idle for a while before turning it off. Even on my .1 GT3 and 991RS it more often than not resulted in the next cold start being smokeless. Its worked on the .2 GT3 as well. The last time I started it was to take the car outside for a quick icy photo and then a quick tuck away back in the garage. I didnt follow my idle down process. Maybe thats why the puff of smoke. Ah well... Im happy for it
#35
So far no overfill warning this time. When i did the oil change i added 7 quarts only. Nothing more, and just let the situation settle. Oil level is perfect. Previous times i would add 7, test drive it, and then check reading, which was always a bar or two low. Adding that extra 1/2 quart would eventually cause the overflow. Now i will just add 7 quarts and call it a day.
#36
Day one, after 550km it showed one mark below completely full. Day 2, after 900km it showed completely full. Day 3, after 1350km it was back to one mark below completely full. Day 4, right after start up, got the overfull warning. I am kind of learning to take the oil level measurement with a pinch of salt...
#37
That's probably why we don't get an analog gauge or a dipstick with the GT3 (analog gauge would confuse many folks while driving and dipstick would read wrong if checked with engine off). Electronic gauge while crappy, does prevent this confusion (even tells you if the car is parked at too large an angle for accurate reading or not warm enough)...
Many people checked the dipstick with the engine off in the air-cooled era and got very wrong impression of the oil level (as well as reading the gauge while driving).
+1 on "where's the dipstick" - why the heck does Porsche hate dipsticks? Please don't tell me for weight saving...
#38
only good advice is stay above the minimum, that's it.
#39
The one in the 918 is 10x times more annoying. I need to read the owners manual each time just to figure out how to measure the oil level. Flying the space shuttle is less complicated. It also calls for 'blipping' the throttle to get the rpm over 3k. But a gentle 'blip' will never do it, I had to mash the damn thing to the bottom just to have the ECU recognizes the 'blip'.
#42
I mentioned at the track this weekend that someone can make a fortune by hacking the minimum PSI settings and make the oil level sensor a quart accurate!
Between low fuel warning at half a tank with 50 miles to empty, TPM warnings and Oil level warning, even when the car is perfect we have messages 3 messages blipping on the dash.. so unneeded, annoying and distracting.
#43
#44
