seat bealts \ third world problem
How hard is it to change the following after market on the 991 series ?
A - seat belt to a different colour ?
B - paint door handle or change to RS style material ( want to remove the silver handles)
C - gear stick top (I see R carbon stick available but is a complete gear lever ?) I only want the carbon top
My spec is locked but considering aftermarket change to work in with some other after market things I'm doing.
Thanks.
Thanks.
Thanks.
Thanks.
B. if you want trim painted talk to bumperplugs.com as they will be able to paint arbitrary trim for you to Porsche color spec... as for RS door straps suncaost has them here: https://www.suncoastparts.com/produc...1GTSTRAPS.html but I believe that you would also require additional h/w *and* door skins to complete this to factory spec.
C. just replace the shifter ... its simply the **** and the boot... https://www.suncoastparts.com/produc...1911RKNOB.html
So the new Carrera T comes with colored door strap pulls (Silver, Red or Yellow). Would not that part from a T be able to be installed in a GT3 as I would assume the door panels are the same?
Thanks.
Chet
Thanks.
Chet
Thanks.
Chet
Thanks.
Chet
I personally would love to see this mod done easily and more cost effective then changing the hole panel.
