How To DIY 991.2 GT3 Oil Change (Video)
5th Gear
Hello Folks!
We just finished this full video of the oil change process for the GT3 991.2. Here's the link:
Enjoy!
-Joe
Enjoy!
-Joe
Thanks for posting!
Good video! People should give you a on YouTube to get more exposure. I gave you the first one.
Also bear in mind when using a torque wrench,that you are losing torque the longer the extension is. So ideally,do not use one if it's not needed.
Looks like the engine drain plug (M16 x 1.5 large new one on bottom of engine w/ 10mm Allen female) is 23 ft-lbs (31 Nm), rather than 17 ft-lbs as stated in the vid. Just wanted to mention to be helpful, not meaning to be critical.
Per your very helpful thread here:
https://rennlist.com/forums/991-gt3-...procedure.html
This agrees with what my dealer tech told me too...
what's the differences between the .1 and .2 filter?
