991 GT3, GT3RS, GT2RS and 911R 2012-2019
Auto Blipper demo
Old 12-14-2017, 05:39 PM
Scott_997
Scott_997's Avatar
Originally Posted by rosenbergendo
You enjoying the car?
Love it! If I had one thing I'd wish for is the size of the 997! Washing a 991 vs. a 997 is a massive difference.
Old 12-14-2017, 05:40 PM
Scott_997
Scott_997's Avatar
Originally Posted by maspirito
I can heel toe just fine but on track when I’m entering a turn off the back stretch at 125 to 140 miles an hour I just as soon have my foot firmly planted on the brake and let the auto blipper work for me.
It made me feel much more comfortable at Dayton, especially going into the bus stop. You don't want to have any issues there!!!
Old 12-14-2017, 05:45 PM
Dr. Ferdinand
Dr. Ferdinand's Avatar
Have it on my GT4, but more often I find myself not using it. Nice to know that feature is there, especially when you want to be 'lazier'
Old 12-14-2017, 05:50 PM
Palting
Palting's Avatar
Or 'faster'
Old 12-14-2017, 05:52 PM
Scott_997
Scott_997's Avatar
Originally Posted by Palting
Or 'faster'
When your out with RS' or 991 GT3's you engage the switch, when your doing solo laps, who needs it?
Old 12-15-2017, 11:15 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,683 Likes on 782 Posts
I think its a nice backup feature when your in max attack mode; if you miss a good blip on the downshift, its saving the gearbox and clutch.
I think the car sitting at redline? it can even warn you of a possible money shift.
Plus when you're in lazy traffic its still fun to make blippy noises with winter boots on, or high heels for the girls
Old 12-15-2017, 12:57 PM
NVRANUF
NVRANUF's Avatar
It will be nice to have the option.
There's also the option to stick with PDK if you feel otherwise.
Old 12-15-2017, 01:44 PM
CAlexio
CAlexio's Avatar
Received 1,976 Likes on 919 Posts
Auto blooper brings the option of shifting with Pdk-like ease, to your manual car. It also makes for really smooth upshifts with the throttle hang feature (which for some reason seems much more pronounced in the 991 chassis than in the 981). The ability to turn it on and off is fantastic, I especially enjoy braking hard and auto blipping from say 6-2nd hitting each gear.. you get riflebolt rev sounds I'm superquick succession, you can't do that with heel-toe. Then when you feel like practicing your technique you turn it off.
Really genius.
You can also use it to flat-foot upshift I believe although I haven't personally tried.
Old 12-15-2017, 01:51 PM
brownan
brownan's Avatar
Glad there's an off button.
Old 12-15-2017, 09:49 PM
Larry Cable
Larry Cable's Avatar
Received 3,637 Likes on 2,360 Posts
Sharkwerks bypass sounds amazing ... as for the 'off' button, is this simply *not* running in sport+ or is there a separate button to disable auto-blip?
Old 12-15-2017, 11:01 PM
BCMgunner
BCMgunner's Avatar
i vaguely remember this from the very first press release but haven't heard it mentioned since. Neat-O. This would make the 0-60 delta from the PDK slightly less significant.
Old 12-16-2017, 01:25 AM
Bardman
Bardman's Avatar
Anyone know if it engages the additional cooling mode like it does on the gt4?
Old 06-13-2018, 02:19 PM
HarmonyJim
HarmonyJim's Avatar
What is involved in wiring an AutoBlip system into a .1 GT3RS? Where is the control unit usually located (as I certainly don't want to look at it in the cabin)?
Old 06-13-2018, 02:23 PM
Larry Cable
"autoblip" is a function of the ECU and the TCU (if there is one - which there isn't on a manual car - replaced I expect by a sensor determining if its an up or downshift)
SInce the RS is a PDK car, it *already* rev matches the engine rpm when (PDK) shifts occur ....
Old 06-13-2018, 03:11 PM
HarmonyJim
HarmonyJim's Avatar
Larry, to clarify, my RS is an older .1 (2007), and therefore does not have PDK or an auto blipper. I was wondering if I needed to cut into my wiring harness (multiple?), or had to run wiring to hell and back to make it work.
Quick Reply: Auto Blipper demo
