Oh....it's my 991 GT3. I'm trying to put it up on jack stands. I know...get the JackPoints, but they are back ordered.
I already have Jackpoints, but also curious if there is a central lift point in the rear - this can be useful. I assume it's not wise to place a jack under the engine (after removing protection plate and inserting a hockey puck), as was commonly done in the air-cooled days...
That's a crossmember directly bolted to the chassis. I don't see any reason to not use it.
My thoughts exactly...until I started wondering if it was aluminum and could potentially buckle right in the middle as I lifted.
I think I'm going to stick with lifting at the chassis point where the lower control arm and that cross member meets...or just directly under the rear tire.
Lifting the rear on the engine will exert force on the engine mounts, in the wrong direction they were design for. I don't know if that's good or bad.........
