Light weight battery options for 991.2 GT3
What are my choices for getting a light weight battery for my 991.2 GT3? Braille? I am a newbie on this.
Thnaks.
Thnaks.
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
under car warranty i would choose porsche original lithium batrery
i mean buying from porsche a Li batrery after the car delivery
Voltphreaks or Braille are the 2 leaders.
Why bother with the porsche OEM LiFe? It is uber-tiny and won't survive the winter and it has the "Porsche tax" since it is filled with Unicorn Tears™
I am pretty sure Voltphreaks used to make a model that even had a small reserve battery that you could switch to and get the car started 1X. http://www.voltphreaks.com/technologyodp.php
The braille one I was going to get for my R8 was an all-season model: https://www.braillebattery.com/index...atteries/i48cx
I have used the Braille i48ce in my 997RS and .1GT3 for years. I will probably get the cx for my .1RS, for the additional power.
Gary Savage at Braille is great to work with.
It seems like the i48 is the "Goldilocks" of the lithium battery world..
its just the right size/capacity!
(The only reason I never put it in the R8 is that you have to disassemble the front of the car to change the battery! LOL!)
If my .2 GT3 allotment rings true, I will surely put one in.
Looked it up quickly and seem like a real value add to these cars
Braille Lithium delivers a higher, cleaner voltage which improves the performance of every electrical component and has shown to provide:• Quicker starting (a full volt higher than lead and less voltage drop during cranking)• Improved engine management & data logging performance (more stable voltage)• Less horsepower draw from the alternator due to efficient charging (5 times faster than lead),• Lasts 3-5 times longer (especially under the harshest environments),• Much more reliable (less than 1% failure rate)• Significant weight savings. (up to 1/4 the weight)• Don’t self-discharge, so if the battery is disconnected (no draw or via power disconnect switch), they can sit for over a year+ and still maintain over 13 volts to start the vehicle.To get all these benefits in one simple step makes it a very cost effective upgrade!!
i48CX
- Weight10.5lbs / 4.8kg
- Length11" / 279mm
- Width6.8" / 173mm
- Height7.7" / 195mm
- PCA1520
- Ah25
- PbEq75
- Right Side Positiv
