2018 991.2 GT3 factory exhaust issue
ISSUE FIXED!!! SEE POST #11
Hey everyone,
My 991.2 GT3 was delivered to me exactly a month ago. It's the first and only one in India for now! Since there's no second car that I can compare mine with in the country, I need you guys to help me out with a query. A clarification from you guys would be a lot better than going to the service centre first and getting it checked from technicians who would be seeing such an issue for the first time themselves
So a few days back, out of curiosity I started her up and checked how much of a throw the exhaust has :P. Turns out that the left tail pipe has a really weak pressure/throw than the right side and this is the same case with valves open or closed. I could literally blow air into a balloon with more force. I have checked it again and again after driving around as well, but the difference persists and feels abnormal to me. The right side has a proper throw.
Now that so many .2's have been delivered, I'd appreciate if any one of you (more observations are always better) could just put their palm facing the tail pipes and check the pressure of both sides. Please help me out, it'll only take 5 minutes!!
Attaching a picture where you can see residue in the right tailpipe, which has proper pressure I believe.
Hey everyone,
Ok I just checked my car and all seems normal. Flow from both exhaust pipes are the same with or without the sport exhaust on. I also do not see any carbon build up in the exhaust. The car has about 220 miles on it. You may need to take the car to a dealer to take a look at it.
What would cause an imbalance? Either an exhaust leak (should be evident) or a broken flapper?
How does the car perform? Is it sluggish or hesitating?
I would take the car in just to give you peace of mind. I assume your hesitation to do so is the dealer is not near you.
And, keep in mind that the center muffler mixes the exhaust flow from the headers. So, the low flow on left exhaust tip is probably caused by something in the center muffler itself.
Thanks a tonne for this info as I had no clue about this. Seems like a really weird issue to me now!
So the technician from the local Porsche Centre came over to my place, to have a look at the exhaust issue. He connected the diagnostics and all seemed normal. He then put his hand under the car to check the flapper mechanism and he felt it work (this is what he said) when it turned on and off. According to him the flow in both the pipes is equal when the flaps are closed and when they're open the right one has a much higher flow, which he says is completely normal. He went on to justify it by saying that the engine management system takes care of how much flow should be there on which side.
I still find it really weird. I can literally keep my palm on left tail pipe when the flaps are open, as it blows somewhat cooler air. Don't know what to do!
Have you ever tested exhaust flow or temps on other cars?.. I’m thinking you might be worrying about something which is inconsequential. just go drive your car and enjoy it, this doesn’t seem like a problem.
This is what I found the issue to be. The flapper inside the exhaust pipe was disconnected from the actuator.
This is how it's supposed to be.
I have finally managed to find the cause and fix it myself. The connection is till loose, as I went for a drive after fixing it and when I got back home it had slipped out of place again. Looks like being OCD about such things isn't bad after all, as the flow felt abnormal for sure and it was because of the above reasons.
I had zero hopes from the local Porsche service centre guys, and my doubts about their capabilities came out to be true when the technician passed it off as normal. I hope this issue wouldn't have affected my engine as I have completed 1100 kms with a closed flap on one side
Any views on this would be appreciated
Well done for persevering with issue. I suggest going back to your dealer, telling them what the issue is, point out their incompetence, and let them fix the car (new part or official fix), and get compensated!
OCD is good at times, OP.
Further to what haku stated above.. Since your location may not support multiple dealerships within a reasonable distance, you should really take this up with both your service manager and general manager. I would recommend not ripping them apart, but speaking with them so that you can share the knowledge you have gleamed on our own. Better to educate in this situation and help to better the relationship between yourself and those 2 individuals. Having the Service Manager on your side is always a good thing when it comes down to any warranty or service work issues that you may encounter down the ownership line.
GL and GJ on troubleshooting.
Thanks!!
