LEAST intrusive rear rollcage recommendation
I’m looking for the least intrusive rear rollcage, something which could offer some rollover protection, a place to attach restraints, but minimal blockage of access to the space behind the rear seats... ideally something which goes around the perimeter, but doesn’t creat an “X” right in the middle. I️ realize this could comport some reduced strength vs the highly braced clubsport package cage. Thanks for any info.
I m looking for the least intrusive rear rollcage, something which could offer some rollover protection, a place to attach restraints, but minimal blockage of access to the space behind the rear seats... ideally something which goes around the perimeter, but doesn t creat an X right in the middle. I️ realize this could comport some reduced strength vs the highly braced clubsport package cage. Thanks for any info.
That being said, Im on the fence about going that route vs just having a custom harness mount made (I have a design in kind). The custom mount would just give you a place to attach harnesses in the back and would not provide any supplemental roll-over protection, but in exchange the interior would be wide open without a jungle gym back there.
the RGT starts life as a 911 body-in-white, it's built from that point on with mostly Ruf-built (or Ruf-specific) components, starting with its integrated rollcage.
http://ruf-automobile.de/en/manufacturing/historie/
https://www.google.com/imgres?imgurl...act=mrc&uact=8
Received 1,149 Likes
I do not think this bar would add much if any rollover protection, maybe if the impact is from a specific angle, but even that seems far-fetched. But on the other hand, all aftermarket cases look like straws compared to B-pillars in 991, and even less sturdy cars (e.g., merc C-class) can hold 7 weights on the car concentrated mostly on one side around B-pillar before the roof shell collapsing more than 2 inches (http://www.iihs.org/iihs/ratings/veh...s-4-door-sedan). That's an unlikely worst-case scenario test. More realistically, the impact would be spread more, so well over 10Gs should not cause a fatal roof collapse. Coincidentally, 10G-12Gs is where serious damage starts from upside-down deceleration (or downward acceleration). The human body is very poorly suited for upside-down deceleration and just 2-3gs for a couple of seconds would cause red-out, and 12Gs for 0.1s is considered the maximum tolerance limit. So my point is that in modern cars the window for a crash strong enough to collapse the roof but still be survivable otherwise is very narrow.
This bar is made by a place called Autohaus Hamilton in Australia, but they don't export. It's basically just a bar with end plates that bolt to the same structure in the back as most all harness bars.
The part with cross-bars is attached to the rear towers. The front part attached to seat bolts has no cross-bars, so it preserves 100% of cargo space and rear seat movement. For minimal intrusiveness GMG RSR is perfect - there is basically no sacrifice.
