Dundon 321SS Lifetime Center Muffler: 991.1/991.2 GT3 RS and 911R Intro Buy Is Open
Most of us have experienced the many issues associated with both the stock Steel and Ti rear mufflers on our beloved 997.1, 997.2 , 991.1 and 991.2 GT3, GT3RS and 911R. cracking, holes, not passing sound etc... We've been reinforcing both the Steel and Ti versions for years after they crack and understand why they fail quite well. We set out to fix the weakness of the OEM center muffler and include an option for those that want their car to pass the more and more prevalent dB restricted tracks without losing power. We finalized the design and have tested at numerous tracks both for longevity and for dB reduction.
Prevent this from happening to you! https://cimg6.ibsrv.net/gimg/rennlis...ba2b8a07fa.jpg Cracked Ti Rear Muffler We're happy to officially announce our 321SS Lifetime Center Muffler for the 997.1 and 997.2 GT3/RS is available. We've made it in 2 versions "Black" (louder than OEM) and "Orange" (quieter than OEM). We're putting together 50 pcs in total for the first batch, 20 or so have been pre sold. We expect delivery to begin by early November (all parts are in production now). "Black" (Loud) 321SS Lifetime Center Muffler
Intro Pricing is over, Check website for current pricing Go to our website www.dundonmotorsports.com/porsche/gt3-lifetime-center-muffler Any Dundon Header customers contact me... 4" Slashed Tips on 991 GT3 (tips will be 1/2" longer on production units, and Muffler will sit a little higher in the car). Hardware provided will be Black as well. https://cimg1.ibsrv.net/gimg/rennlis...4916716e05.jpg 4" Slashed Tips and Tip Plate (turnaways bolt to the tip plate as well) https://cimg2.ibsrv.net/gimg/rennlis...51b1e4bbd7.jpg 4" Slashed Tips and Tip Plate (turnaways bolt to the tip plate as well) https://cimg3.ibsrv.net/gimg/rennlis...d5423830cf.jpg Reinforcing Stitch Plate https://cimg4.ibsrv.net/gimg/rennlis...268c1be891.jpg Under Skirt Shot (Tubing will be flush with the Tip plate on production versions) https://cimg5.ibsrv.net/gimg/rennlis...f9164ace58.jpg Tip Plate (Tubing will be flush with Tip Plate on production versions) https://cimg6.ibsrv.net/gimg/rennlis...f25961241a.jpg Reinforcing Gussets https://cimg7.ibsrv.net/gimg/rennlis...80607241aa.jpg Reinforcing Gussets https://cimg8.ibsrv.net/gimg/rennlis...0325e2fb6e.jpg Orange (Quiet) Center Muffler on the Dyno |
Shells have arrived production has started, and don't miss 6% off through Monday!
https://cimg1.ibsrv.net/gimg/rennlis...f840a6d0aa.jpg Dundon Lifetime GT3 Center Muffler https://cimg2.ibsrv.net/gimg/rennlis...59eb4ca6b0.jpg Dundon Lifetime GT3 Center Muffler |
This is a totally honest and not an incendiary question, but why do these center mufflers look so bad? Welds aren't even, I don't understand why there are bits that are open (reinforcements?), and why does it look so banged up?
What's the increase in DB from the black muffler center vs OEM? |
Originally Posted by RennOracle
(Post 14627820)
(Post 14627820)
What's the increase in DB from the black muffler center vs OEM? First, I think people in general have grown used to seeing welds that are "polished" afterward so that there is no heat signature remaining color wise to understand the quality of the weld. The "rainbow" welds that everyone sees and are enamored by are actually poor torch control as the color is from the oxides that grow on the metal due to varying temperature. Varying temperature creates varying stresses in the metal and a weaker overall weld. Completely silver welds the same color as the rest of the metal means likely that the muffler has been polished after welding... Don't get me wrong there are some that do wonderful welds, but anytime you see a product polished to a mirror finish after welding you less ways of seeing the quality of the welds. Now to your specific questions. 1. This is a prototype, the finished product will have a more consistent appearance. 2. The tabs and slots we are using to construct and reinforce the muffler, locking it together, are what is poking through and make it look "beat up". These are fused (tabs melted with a torch and fused to the plate) for the ultimate in strength, not welded with rod. The consistent golden color at the fused tab is what you're looking for to show a consistent amount of heat. The fact that there are golden areas and non golden areas makes the muffler look "beat up". 3. The open areas on the front in line with the tips is a reinforcement plate over one of the seems, further working to make the muffler bullet proof 4. dB increase of Loud vs OEM from our testing is about 10dB at wide open throttle, it also has a bit higher pitch due to the 3" diameter internals and design of the merge. You can hear a drive by with Race Headers and Black Center Muffler here: http://www.dundonmotorsports.com/blo...n-race-headers Let me know if you have any other questions! Thanks Jamie |
I'm just glad that you have a "quiet" option.....with all the tracks clamping down on sound emissions, you have the only product that answers this need!
That sounds extremely good, damn. :cheers:
So, the loud version is comparable to a center bypass when valve is open? And how about the sound and noise-level when the valves are closed (with side delete / long tube headers)? 991.1 GT3.
Jamie, do you have a video of Orange with race or catted headers with side deletes? What is the db difference in Orange and black with valves open and closed? Thank you!
Originally Posted by Earlierapex
(Post 14632697)
Jamie |
Originally Posted by Cay_PI
(Post 14630747)
Jamie |
Thanks Jamie. I currently use the fvd center bypass and have a switch to permanently open the valves.
When we compare this to your catted long tube headers and the Loud version of your center muffler: what would you expect (in terms of db and quality of sound) in case of: -> valves forced permanentely closed / gps -> valve controll stock -> valves forced permanentely open ? Thanks. |
Great stuff!
How quiet are the street headers/exhaust compared to stock? I track at a track that is limited to 92db at 50' measured at 2 places on track. Some stock 991 GT3's, RS's and even GT4's pop sound with the valve open...on stock systems. What are the chances i stay under the limit? |
(Post 14630747)
(Post 14649391)
When we compare this to your catted long tube headers and the Loud version of your center muffler: what would you expect (in terms of db and quality of sound) in case of: -> valves forced permanentely closed / gps -> valve controll stock -> valves forced permanentely open ?Thanks. http://www.dundonmotorsports.com/blo...rgia-mountains The Loud muffler with GPS closed valves will be a bit louder than stock as the muffler has larger tubing The Loud muffler with normal valves will not drone, would be quieter at idle vs your current setup with valves open, no drone and a nice flat six wail when the valves are open The Loud Muffler with valves open all the time would be about the same as your bypass with valves open, could possibly drone a bit between 2500-3000rpm (where the factory program closes the valves). With the street headers added to the above would take everything up a bit on the dB scale as the Dundon Street headers increase cylinder pressure (produce more power) and the resulting pressure wave coming out of the exhaust valve is stronger (higher pressure is higher dB). All of the above is true when the car is under power, when your idling and cruising around the catted system is very close to stock with a side muffler delete.
Originally Posted by Chris R.
(Post 14649965)
Great stuff!
How quiet are the street headers/exhaust compared to stock? I track at a track that is limited to 92db at 50' measured at 2 places on track. Some stock 991 GT3's, RS's and even GT4's pop sound with the valve open...on stock systems. What are the chances i stay under the limit? The Street headers and side deletes are similar to the stock car with side deletes, but I'd want to see where your car is first with just the muffler, since getting black flagged for sound is no fun... Jamie |
Jamie is the man! Had a long discussion with him about their headers and this new muffler a few days ago.
As soon as the winter passes up here in the Northeast, I will be extremely tempted to buy the full Dundon setup. If anyone purchases this with Dundon's race headers.. please for the love of raptor jesus post some clips of the way it sounds! |
Anxiously awaiting my quiet muffler.
