Center Lock Wheel Tool Suggestions Please
#32
LOL. Okay, here is what I do. Car is on my lift, tires off the ground. I put the CL tool and breaker bar at about 8-9 o'clock position, then I STAND on the end of the breaker bar. I weight 200 lbs, and I still have to give it a little bounce to loosen the CL. I am NOT, repeat, NOT pulling UP on that sucker.
#33
Originally Posted by GrantG
Which model 991 and which wheels? Would be interested if GT3 forged wheels (occasionally bent, but haven't seen a catastrophic failure posted).
#35
The torque multiplier should make loosening easy, just as it does tightening. Obviously you'd use a much smaller ratchet or breaker bar with one. I have a separate breaker bar nearly as long as my torque wrench that I use.
The Precision Instruments torque wrenches break down to 3 pieces. They make breaker-bar attachments for them that replace the torque wrench section. I find it easier to have a separate tool than to have to swap the handle back and forth, especially as the procedure is to torque, loosen, then torque again.
#38
You should never use a torque wrench to loosen anything. They're precision tools meant for tightening to a specific spec.
#39
I need to invest in the correct tools so I can manage the center lock wheels.
Just got back from a 4 day, 1,270 mile road trip and the car was awesome! I'd like to do more trips like this but if I have a tire issue most shops can't help. I'd like to have what I need "on board" and as compact as possible. So I can help them, help me.
Can anyome provide links to required tools ?
Also anyome know what this is tool is in the video link below? A Part number or link to it would be great. Looks compact and able to apply the torque required in a small package.
https://m.youtube.com/watch?v=GzpTU7lBxBA
Thanks in advance.
Thanks in advance.
#40
