Ridge in middle of AP rotors
Basic Sponsor
When I put in the rear AP rotors, it apparently threw off the parking brake sensor due to the rotor being a bit thicker than OEM. Has anyone else experienced this? My shop said it won't affect engagement and disengagement of the parking brake, but I find it annoying and a bit disconcerting to continue seeing parking brake warnings.
Our discs are almost the exact same thickness as the OEM units. The rear OE disc we used to evaluate measured 29.92 mm. Our discs have a nominal thickness specification of 30.00 mm. The Inner Diameter of the OEM parking brake drum measures 7.089". We specify on our drawing 7.089” +/-.005”, and our production parts are all measured on a Coordinate Measuring Machine (CMM) for accuracy as part of our QC check.
Have you checked your parking brake pads for wear?
Also, we have these installed on quite a few cars at this point (some of which are literally tracked every day), and have never had a report of any parking brake issues/compatibility.
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,424 Likes
I'm thinking that you likely have something other than a disc thickness issue going on. There's no reason to believe disc thickness would impact the parking brake functionality.
Basic Sponsor
I've seen the same grooving on other slotted rotors (mine and on other cars). It occurs at the end of the slots. At first it concerned me, but seeing it on other cars makes me believe it's normal.
God, you have know idea how much this bothered me....
Cicadas...the noise sounds like cicadas.
I love the look of my AP rotors, except for the rust all over the non-swept parts of the iron rotor. Wish they would do a simple costing on the rotor so they looked nice everywhere!
Former Vendor
For those who are in serious tracking should consider RB's two piece rotors like Corvette Z06 guys' consensus in this thread where all major brands' are mentioned and compared.
Best 2 pc light weight rotor for grand sport...
Read more: http://www.corvetteforum.com/forums/...#ixzz3xjrMXpXV
We guarantee an even disc surface across (except spider cracks) for track application provided the calipers are in good shape*, or the disc will be replaced at no charge.
You can also search around Nissan GT-R forums and learn why RB is the most favored two piece rotors by those track guys.
Front caliper; http://www.racingbrake.com/SearchRes...nsive_Search=Y
Rear caliper: http://www.racingbrake.com/SearchRes...nsive_Search=Y
Our high temperature (Blue) dust boots are also guaranteed to outperform OE (provided no contact to brake fluid), and other aftermarket boots or your money back.
http://www.gtrlife.com/forums/topic/..._fromsearch__1
http://www.gtrheritage.com/topic/268...ake#entry43782
*RB also has the upgrade "one piece" stainless steel pistons that never crack on you, and high temperature dust boots that can protect your seal and brake fluids here:http://www.gtrheritage.com/topic/268...ake#entry43782
Former Vendor
Upgrade front to CCM rotor
Upgrade to RB CCM rotors and benefited from the latest braking technology and forget all about these stated concern.
We offer a very affordable and flexible combo:
Front: RB/ST CCM (disc made by Surface Transforms)
Rear: RB light weight 2 pc
Total weight saving ~36 lbs over OE set up, yet at highly affordable price (cost fraction of pccb), and run at lower maintenance cost.
Please join discussion here:
https://rennlist.com/forums/991-gt3-...l#post12948545
Basic Sponsor
Former Vendor
Our iron rotor casting are from Taiwan, CCM discs are supplied by Surface Transforms from UK.
All design, assembly and test are done in our So cal facility in Fullerton, CA, a 30 year US brake company.
We can only speak for ourselves, however you might be surprised to learn that those claimed their parts are made in US, Europe, or Japan are actually sourcing from China (whole or part), but company like Chevy of course must disclose their sourcing from China, so are you going to question Chevy's quality or their source or origin.
We believe more optional choice is always good for a consumer. Despite we have quite a few local subcontractors supply us our brake components, I still believe presenting the design and technical merits of our brake is a better approach to win customer' trust than making source of origin as a big deal.
