Chris’ Cayman
#121
I daily'd a VW GTI Mk5, which has a similar oil filter cartridge housing to our 9A1, but the filter housing has a cap which can be unscrewed and there's a drain valve. There's aftermarket hoses which can be attached to the drain valve. Wish there was a similar housing available for our Porsches to keep things clean.
CAinCA (05-19-2023)
#122
Zach - seems like a great idea to submit here, https://rennlist.com/forums/987-foru...ent-ideas.html
ekam (06-12-2023)
#124
A minor update: I've owned this car for just over a year and put ~15k miles and 6 track days on it. I've really enjoyed it. It was cheap enough that I don't feel bad racking up miles or track days on it. I've just done basic maintenance (oil changes/air filter/DSG fluid/filter) and swapped the brake pads over for track days.
The adjustable lower control arms in the front and track(ish) alignment have been all it really needed to make it a decent track day car. The PS4S street tires have 7k miles on them and still look good. The extra camber doesn't seem to be wearing them abnormally.
I'd be lying if I said that I haven't been tempted to buy something faster (newer Cayman S/GTS, C8?) but I'll probably hang onto it for at least another year or two. Once my son graduates college I'll probably look for an upgrade.
CAinCA (06-14-2023)
#126
I love it. A lot. But oddly enough, I find it's really similar to my 2013 NC Miata. Even the cockpit feels similar. Both silver exterior and black interior.
Yeah, the Porsche is faster, but there is something about that Miata.
I can see wanting a Guards Red 981 GTS with Beige leather someday. Right?
CAinCA (06-14-2023)
#127
Last Saturday at Laguna Seca was interesting. It was HOT, at least for Laguna. The temperatures were in the low 90's all day. My car was HOT, like 240F by the middle of each session. The new surface was great. I was able to brake about 1/2 marker later on every turn. Unfortunately that really didn't translate into much time wise. I think I shaved .2 seconds off my personal best. Also, for some reason my RaceBox Mini would not connect to my iPhone. I wound up renting a transponder and using my iPhone for GPS data in RaceChrono. So, the time is real but everything else is weird in the video.
While I was swapping the brakes and tires over the weekend I noticed that the left outer CV boot is torn. It looks like it happened at the track since there was grease on the inside of the wheel. I made an appointment to have it and the spark plugs replaced since they have about 30k miles on them.
The Goodyears look like they are done. I got 4 track days and a few hundred road miles out of them.
I also ordered a center radiator kit from Suncoast Porsche Parts. I don't want to deal with the car overheating while I'm at the track.
The Duke (10-17-2023)
#128
I installed the third radiator last weekend. It went fairly smoothly until I realized that they shipped the wrong grill for my car. I emailed the vendor and had the correct grill two days later.
I dropped the car off at my local indy P car shop and gave them a laundry list, spark plugs, belt, CV boot, coolant flush, general inspection. It should be done this afternoon.
I also ordered a set of Nankang CR-S V2s to try out. They seem like a good tire for my needs based on Andy Hollis' from GRM and Rennlist reviews.
Finally, I signed up for a track day at Sonoma on the 19th. I'm looking forward to trying it out again.
#129
I hit Sonoma for the second time on Sunday. It rained on and off most of last week but finally stopped at 5PM on Saturday afternoon. Sunday morning the track was still damp and it was only 48F outside. By the second session the track had mostly dried out and I started to get a feel for the tires. They felt pretty good overall but got a little nervous towards the end of the session. I dropped the pressure targeting 33psi HOT and my times kept getting better but it took 2-3 fast laps before the tires would come up to pressure. I wound up with a personal best 1:59.65 in the forth session. I lifted coming out of 7 to give myself some space to the cars in front and from the data that cost me about .8 seconds. Watching the video there are a couple places I could improve. I'm consistently hugging the left side between 1-2 and need to be further right. I'm also turning in too early on 6 and 10. The Nankang CR-S V2 feel really good. I was able to drop my personal best time by almost 4 seconds compared to the Goodyear Eagle F1 Supercar 3's.
The following 2 users liked this post by CAinCA:
quickboxster (11-21-2023),
sasilverbullet (11-21-2023)
#130
https://youtu.be/oKvXgB1TE6w?si=X-OErmbCLhYVuNpB
#131
I had another HPDE at Laguna Seca on Saturday. It was 37 degrees when I got there. I think that's the coldest it's been when I've been here.
I dropped my pressures to 25/26 cold before the first session. I wound up at 35/36 hot. The funny thing is that the car developed a little oversteer towards the end but my lap times kept dropping. I had a series of 49s and 48s then a 45 and finally a 1:44.37. That beat my personal best by 3.6 seconds. I dropped the pressures down to 31/33 hot afterwards. I managed to knock another 3 tenths off my time in the second session. 1:44.07. RaceChrono says I could shave another 2 tenths off if I combined my best sector times. The last two sessions it's warmed up into the low 60s and there was a bit more traffic. These CR-S are easily 3 seconds a lap faster than the Goodyear Supercar 3s. I didn't manage to lower my PB any more after the second session, but my average times were consistently lower each session. I had multiple laps in the 1:44-45 range in the last three sessions. I was going out with the tires at 23/24psi cold (65F). They would get up to 28psi by the end of lap 2 and I felt comfortable pushing them hard from that point on. They were around 31/32.5psi by the end of each session. The temperatures were very even across all four tires. The rears do seem to want to be a little lower as they are still a little hotter in the middle than at the edges (+5F or so).
Needless to say I'm really liking these Nankang CR-S. Highly recommend.
Apex Wheels (12-11-2023)
#133
I installed a new pair of rear PS4S on the car on Saturday at 74,550 miles. I got 10,800 miles out of my first set.
CAinCA (12-21-2023)
CAinCA (12-21-2023)
