Lifting rear with rhinoramps, how should I lift the font?
Hello,
I got some rhinoramps to lift the rear of my 987 Cayman S for oil changes but they are much shorter than my jack stands. What could I use to lift up the front of the car 5-6 inches to match the rear? |
Jack the front of the car up from the recommended lift points and place blocks of wood under the front tires. |
Originally Posted by Jim137a
(Post 15714903)
https://cimg0.ibsrv.net/gimg/rennlis...d72e1a39a.jpeg I’d nail or screw a few 2” x 6” or 2” x 8” ‘s together to get the height you’re looking for and then I’d screw or nail a chock if front of the tire and a chock at the rear of the tire. You’re looking to form sort of a cradle. Heres a poor sketch of of what I’m suggesting - the black rectangles represent the 2 x 6’s and the red squares represent the chocks. |
Just get another set of ramps and lift using the recommended points. You could do this incrementally by placing wood under the left tire after lifting it a few inches, then jack the right side up and place one ramp underneath, then jack the left side again until the other ramp fits.
https://cimg3.ibsrv.net/gimg/rennlis...444a51cd15.jpg |
(Post 15714952)
https://cimg0.ibsrv.net/gimg/rennlis...d72e1a39a.jpeg I’d nail or screw a few 2” x 6” or 2” x 8” ‘s together to get the height you’re looking for and then I’d screw or nail a chock if front of the tire and a chock at the rear of the tire. You’re looking to form sort of a cradle. Heres a poor sketch of of what I’m suggesting - the black rectangles represent the 2 x 6’s and the red squares represent the chocks. Peter |
(Post 15714952)
With 4 cars in my household, I got tired of playing the game with jacks and jack stands for the big and small jobs, especially the Cayman oil change. So, I bought a QuickJack 5000SLX from Costco when it was on sale last month. Honestly, I am kicking myself for being a cheapskate and not buying it a long time ago!
https://www.quickjack.com/car-lift-s...-car-lift.html |
Originally Posted by catamount
(Post 15733036)
Originally Posted by SpyderSenseOC
(Post 15733064)
Is there a mechanical device of some sort holding it in its extended position? Toothed rail or similar? Can't just be hydraulics, right?
I've circled it in this photo. https://cimg1.ibsrv.net/gimg/rennlis...5910d43eed.jpg |
I have one of these also. Pretty nifty.
I've got one also and have been very happy with it. Would definitely buy it again. Home Depot recently had these online for 30% off.
I also have the quickjack 5000. It stores in about the same amount of space as the ramps you are using. The best thing is that they get your car high enough that you can actually get under there, roll around, and see what you are doing. I also own jack point jack stands as well as craftsman jack stands neither of which I ever use anymore. If I was starting over, the quickjack is all I would buy. So simple, so safe, and so high of the floor.
