Hacking the GTS Synposium Sound system ?
Has anyone done this to change the settings ?
Yep. I put a plug in it.
Same here
Pulled down the carpet behind the passenger seat and stuffed some foam insulation in there. |
Originally Posted by Ryun43
(Post 14485196)
Same here
The system is nothing more than a plastic pipe that runs from the intake to the engine bulkhead behind the passengers seat. I suppose the carpet on the bulkhead that covers the tube opening could be cut and removed to unmuffle some of the sound. otherwise I'm not sure there is anything else to be done.
Does the GTS have more sound in the interior than an S? Does the S have a symposer?
I think it's only the GTS of the 981:s that have a symposer. And I agree with DBH, although if you could get into the electronics, you could maybe change the engine speed/load at which the control valve opens. Not convinced that that necessarily would give you "more" (or nicer) noise though.
Originally Posted by DBH
(Post 14485969)
1 Attachment(s)
No, no electronics involved, other than the control valve. Only pic I have is from the engine compartment. Follow the long hose to the right up to the bulkhead, there the hose just ends in an opening, behind the carpet.
Each to their own, but I must admit I am a little surprised that you thought the symposer was a speaker based device (i.e. fake sound a la BMW M) and that you wanted "more" of that... When you have one of the sweetest, naturally sounding engines currently existing (or actually not anymore...) behind your back.
Erikplus, do you have the a view of the part numbers?
Originally Posted by erik_plus8
(Post 14486819)
I checked the PETs I had on my laptop but no luck, they were for the 981S and GT4, sorry.
But why do you need part no:s? Are you thinking of after install? For me personally the symposer didn't add to the experience, quite the contrary. It's not artificial (as a speaker based system is), but it's just that the sound changes in character at a certain engine speed and I wanted a more natural progression of the sound. Hence, the plug in the system. I am sure the same result can be had by unplugging the connector to the control valve, but I wanted to avoid any risk of a CEL. |
Originally Posted by Dr.Bill
(Post 14487619)
So if we were to remove that plastic hose we could get rid of the fake, artificially enhanced noise? Sweet!
But aside from that - yes! (Although if you remove it you need to plug both ends, especially close to the intake manifold, upstream of the membrane (the big mushroom shaped thingy), because that would create huge leakages and a definite CEL...) |
The hose needs an adjustable aperture, official acronym and a high price tag option. Porsche exclusive VSSS. (vario sucking sound system)
