Install X73 Spyder version on Boxster S?
x73
As an alternative, I went for the ST tuning coil over set up (KW1 essentially) together with Pedro garage rear bar. Mnimally firmer ride, less
roll and right height. About the same $$ As OP described.
What does "oem SS" stand for in your sig?
Why did you choose that over the x73 route?
Anyone has the f/r spring-rates for the base and x73 suspensions?
Looking at 981 boxsters and strongly prefer the lowered x73 look but most of the cars don't seem to have this option.
Is there a good way to just lower a 981 with base suspension without compromising anything too much? I used to have a 987.1 Boxster S with base suspension and loved it on our not always perfect NE backroads.
How does the x73 retrofit compare with the after-market suspension options?
What do you do with the base suspension parts after an x73 retrofit? Is there a market for them?
Thx in advance!
Thx in advance!
I did the X73 conversion on my '14 Cayman S and, while I felt it was well worth the money (~$3k IIRC), it makes the ride a LOT firmer. So if you like the soft, supple ride of the standard suspension, the X73 is not for you. But if you want a more responsive car, flatter cornering and a much nicer stance, it's a great option. Note, if you do have it done, make sure to remind the tech to reconnect the PDLS wiring before they reinstall the front sub-frame. Easy to forget apparently, and the entire subframe needs to be dropped again to reconnect them.
Ssk-short shift kit. For track/DE, you may want the sway bars (I wanted the height lowered and ride maintained as much as possible). Pedro’s garage website has his suspension upgrade info—Boxster/Cayman oriented.
Valid point. It's easy to think most Porsche owners, especially those using this forum, are like minded in wanting the cars to corner as well as can be but still deliver excellent road manners. One reason I chose the 981 Spyder over the Cayman GT4 was that I didn't want a track car for the street. Nor the attention of the GT4 but that's off point. I have a history of owning sporty cars and sports cars since my first BMW 2002 in 1976. I'm very used to taut suspensions but I definitely don't like crashy suspensions which are jolting and loud over both low and high frequency bumps. I owned many cars which were so crashy that you had to modify the suspension just to live with it. That's no fun. The Cayman and Boxsters are so brilliant at what they're engineered to do that you simply can't lose with any suspension option. Luckily Porsche saw fit to give owners choices.
Any (long-term) issues with body rigidity (creaks, squeaks) with the stiffer x73 on a convertible?
Zero for me in my '11 Spyder which would count as my long-term convertible w/X73. My Cayman R was the same and I owned both at the same time. Traded both in '16. I don't recall ever hearing a creak in either car no matter the circumstance. X73 is firm but extremely quiet over bumps. Of course I can say the same from my '08 RS60 Boxster Spyder with PASM set to normal. I guess credit goes to the chassis. Porsche knows how to build a solid roadster.
I installed the x73 suspension on a 981 base and it is fantastic!!! Both how the car sits and how it handles. We (my wife and I) do NOT find it too harsh (and our Cayman came with the factory option of 20 inch rims). On the contrary, I found the base suspension (which i believe is the same suspension as the BASE suspension on the S) too compliant when pushed. A couple of things to think about:
Best of luck! -Dom
- Clearance does change when you drop the car 20mm, but I have NOT had an issue with scraping.
- We live in Florida (relatively flat roads with minimal potholes)
- Keep an eye on classifieds - I found an x73 suspension that had been taken off a GTS for $450, including shipping. Needed to buy the sway bars ($250 for both from Sunset + shipping) - so less than half, all in, than from Suncoast.
- Install was about 7-8 hours, and they will need to do an alignment, obviously
Best of luck! -Dom
^ That looks like a proper stance now! I’m sure it’s a noticeable difference in handling too.
It’ll settle a little lower over the first thousand or so miles after install.
