981 Spyder roof mechansim issues
Just wondering if anyone else here has issues closing the roof without fiddling with the clamp inside the car?
If I just close the roof, put it on top of the windshield, get in the car and pull the button to have the latch tighten the roof to the car, it usually either misses the place it's supposed to grab or grabs it on the edge, violently snapping off.
The only way to get it to close is by fiddling with the latch and holding it in place while pulling the close button.
I had the car checked by the dealer and they told me the entire mechanism was out of alignment. They realigned everything and it all worked fine for about a week or so (could simply put the roof on the windshield and use the button and it all aligned up perfectly), and then it started again.
I always pay a lot of attention when opening and closing the roof as to not put any sideways force on it so I don't bend anything. But even that is apparently not sufficient.
Anyone here care to share their experiences?
There's already a thread on this thing here. But I just hold the roof down from the inside - there's a grab handle of sorts and then press the button. Works perfectly. I however have the rear trunk open at that time as in not latched all the way. Once the roof is secured in the lock I got and push the trunk lid down all the way and lock it down. No issues. My roof stretches very tight and I like it like that. I think that's the way its supposed to be. That's why to ease the pressure a bit I keep the rear trunk lid unlatched when I do all this.
Sorry to hear you are having issues... I have no issues with mine. Hopefully it stays that way.
My Process:
1. Leave Key in the Ignition turned with engine off
2. Pop Trunk
3. Open Top
4. Close Trunk Completely
5. Attach/Clip the Supports
6. Climb in and Hold the Roof Close Button until the latch closes and the windows go up
I don't have to hold the roof down at all... gravity does it's work for me.
My Process:
2. Pop Trunk
3. Open Top
My Process:
2. Pop Trunk
3. Open Top
My Process:
2. Pop Trunk
3. Open Top
There are definitely two camps here: those that close their trunks before latching the roof from within and those that close their trunks after latching takes place. I'm in the "before" camp, but it sounds like either method works. As I recall from the prior thread on this issue, some who took euro delivery reported Porsche personnel instructing them to close the trunk last, but I've personally never done it that way.
Mine latches from within with no alignment issues so I sympathize with Ir-Fuel. I would stay on your dealer until it gets resolved to your full satisfaction. If the dealer tries to convince you that "that's just how it is," call B.S. and maybe take to your dealer another Spyder owner whose top aligns properly and point out the stark contrast between your respective cars. Good luck!
Yes Jam2 reported that on ED they told him latch first, then close the trunk. When I did ED a month earlier I was told trunk first, then latch. Go figure!
Most important point they told me at ED was that. When attaching the wings, look across to the other side and make sure you cannot see the red tab (so it is locked in place).
I had the same issue in the biggining only. I think the roof just has to work itself and you don't need to pull the roof closer to the A pillar anymore. Not th function is very smooth. Only issue I had that the back latch didn't engage well one time and it came off on the highway. The flapping scratched the paint and had to have it buffed up
I close the trunk as last.
It's not even a matter of pulling the roof closer, even with the roof fully on top of the windshield it doesn't engage correctly. I have to align the latch in the hole by hand for it to work.
I also just realized you can unlock the trunk and the latch as well as lower the windows without using the interior roof unlock switch. Holding the remote unlock does the same function.
