981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
Porsche 987, 981, 718 Boxter/Cayman BBi StreetCup Suspension Packages Available
Old 08-12-2016, 09:41 PM
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Default Porsche 987, 981, 718 Boxter/Cayman BBi StreetCup Suspension Packages Available
Attachment 1344394
BBi Autosport Porsche 987, 981, 718 Boxter/Cayman StreetCup Suspension Packages Now Available
(Click on images for higher resolution)
BBi Autosport is pleased to present our Street Cup Suspension Package to further improve the handling of the Porsche Boxter & Cayman and make it even more track-worthy. With many years invested in development and testing on both the track and street, this complete suspension upgrade package will elevate the driving experience beyond the already impressive factory performance levels.
BBi Street Cup Suspension Components Typically Share The Following Features:
  • Hard tested on the street and track
  • Provides additional adjustment range
  • Helps maintain proper suspension geometry
  • Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
  • Eliminates factory rubber bushings for improved suspension feedback
  • Direct bolt-On replacement and requires no modification to the vehicle
  • Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
  • Precision Teflon lined spherical rod ends for smooth operation and long life
  • Discrete black anodized finish for increased corrosion resistance
  • Made in USA
BBi Autosport Front Bump Steer Kit
  • Helps eliminate bump steer by maintaining proper front end suspension Geometry
  • Utilizes misalignment rod ends of the arm to provide maximum articulation
  • Highly recommended for vehicles that have been lowered
  • Each kit includes pair of 2 Links
BBi Autosport Rear Adjustable Toe
  • Provides additional rear toe adjustment
  • OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
  • Helps maintain proper rear end suspension geometry
BBi Autosport Front & Rear Thrust Arm Kit
  • Connects the Lower Control Arm to the subframe
  • Provides precision caster adjustability
  • Spacers included for setting stock or anti-squat and anti-dive configurations
  • Each Kit Includes Pair of 2 Links
  • Fits both front and rear axles
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
  • Provides two eccentric mounting points
  • Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
  • A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
  • Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
  • Sold as a set of 2 or a Complete set of 4
BBi Autosport Front & Rear Billet Lower Control Arm Kit
  • Improved two piece 996 GT3 lower control arm design
  • Stronger than OEM and cast motorsport Cup arms
  • Uses GT3 shims to adjust camber & lower control arm length (sold separately)
  • High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
  • Sealed monoball inner bearing
  • Allows easy access to inner arm hardware
  • Includes adjustable thrust arm bushings to adjust caster and wheelbase
  • A must have for all track and race enthusiast
Tarrett Front and Rear Adjustable Sway Bar End Links
  • Simple bolt in replacement for the factory drop links
  • Left & right hand threaded rod-ends allow for simple length adjustment to eliminate swaybar preload
  • Correctly sized, precision, Teflon-lined rod-ends for smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low quality rod ends
  • Eliminates the factory compliant plastic drop link bushings that deflect under loading and quickly wear out
  • High misalignment, stainless steel spacers allow for superior bind free operation and corrosion resistance
  • Precisely connects the stock or adjustable swaybar to the front strut assembly for improved feedback and swaybar response
  • Overall length is adjustable to accommodate either stock or adjustable swaybar requirements
For all questions and inquiries, please email Jerry@BBiAutosport.com or Sales@BBiAutosport.com International shipping is available and wholesale inquiries are welcomed. BBi Autosport products are also available worldwide through our growing dealer network in North America, Latin America, Europe, Middle East, Africa, Asia and Pacific. BBi Autosport is always actively working to expand our dealer network worldwide to grow the distribution of our products and better serve our growing client base.
For up to date information of current shop activities, projects, and product releases, please follow us on our Facebook and Instagram accounts:
https://www.instagram.com/bbiautosport
https://www.facebook.com/BBiAutosport
- Jerry@BBiAutosport.com
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
BBiAutosport is offline
Quick Reply: Porsche 987, 981, 718 Boxter/Cayman BBi StreetCup Suspension Packages Available
