981 Spyder - IPD Plenum and headers installed, throwing error codes now
#32
B8E04 error code
Hi,
I have also installed the IPD plenum on my 981 Spyder, and Fabspeed headers. Although all the errors related to the IPD adaptation process are gone, the 0x773 - B8E04 remains active, and from what I remember it appeared since I installed Cobb, and that was having the car on stock, without any aftermarked installed.
Do you still have the B8E04 error? does anybody knows something about it?
#33
Hi,
Greetings ALL,
Can anyone shed some light on the mysterious 0x773 code? I am guessing it is MAF related, but I would like to know more if possible. Any help would be greatly appreciated. Thanks!
#34
I have a 981 and recently installed Fabspeed Max Flow exhaust, IDP intake plenum with new throttle body, Fabspeeds tuning device and aftermarket air filters, all purchased from Fabspeed. I have an error code; The dash reads (Engine Control Fault). I have a ICARSOFT POR II that reads the fault as; (generic map/maf Throttle Position Correlation). The fault can be cleared with an OBD II, but 10 minutes after the engine is running it re-appears. I was told by Fabspeed to have a Porsche dealer fix the fault. Not sure if you fault code is the same. However, you may be in the same boat.....you have to go to a Porsche dealer to fix the issue.
