987 with 150K miles....
I am considering to buy a 987 with 150K miles.
The current owner is the 2nd owner and he has no maintenance record for the car. For this mileage, what are the list of services that needed to be done and what are the list of parts need to be replaced? Thanks :) |
With that kind of mileage and no maintenance records there is the possibility of a long list of necessary work.
Clutch/pressure plate, all fluids incl oil, trans, coolant, power steering, etc, brakes including rotors, spark plugs, O2 sensors, water pump, AOS, serp. belt, possibly all coolant hoses, window regulators, suspension parts incl ball joints, rods, struts, drop links, wheel bearings, steering rack, etc. If the car has had decent maintenance and/or if the miles are long freeway commutes, you may need to only address a few of these issues. In any case a thorough PPI would be wise, including compression testing the engine, and possibly bore-scoping the cylinders as well. Without a thorough inspection you cannot really know what you've got. Some 80K mile cars are fairly worn out while some 150K mile cars can still be solid and serviceable. |
Never buy a used car, especially one with this many miles, without a PPI.
Originally Posted by doridori
(Post 12905186)
Yeap, if you buy a car with 150k miles, its going to need some love.
If your buying a cheap car as a project then go for it, but I wouldn't spend money on an inspection for this car if your looking for a car that's perfect. |
BTW, if the second owner you're looking to buy the car from has owned the car for any length of time and he has zero maintenance records for the car, I'd walk away. I'd never buy a car from someone who couldn't document the maintenance history, at least in some fashion.
Originally Posted by 981spyder
(Post 12906883)
Originally Posted by Archimedes
(Post 12906949)
Maintenance history can sometimes be tracked down by querying the last owner about the locations and approximate dates of service he might remember. You can then follow up with the businesses using the VIN and car description to verify service history. |
I recently bought an '07 with 102k miles from the original owner. EVERY service with the exception of tires was completed at original Porsche dealer where the car was purchased. There were some $10K in receipts in just the past year (New clutch, brakes, scheduled maintenance and inspections, etc). The car's condition is exceptional to start with, but regardless, I wouldn't have bought it if it didn't have so much proof of maintenance.
Originally Posted by SoCalDan
(Post 12927092)
