BBi Autosport Black Friday Sale 987 Boxter Cayman Suspension & IPD Plenums
Old 11-27-2015, 09:44 PM
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Default BBi Autosport Black Friday Sale 987 Boxter Cayman Suspension & IPD Plenums
Attachment 1358175
This year has been great to us and Thanksgiving is great time to show appreciation for the love and support from our customers and friends. We are running a special Black Friday Sale promotion for on our entire BBi Autosport catalog, along with selected products from our partners. Here are the BBi Porsche 987 Cayman upgrades that will be on sale:
IPD Porsche 987.1 Boxter / Cayman Plenum
Competition Version Available with 82mm Porsche Throttle Body
IPD Porsche 987.2 Boxter Cayman Plenum
Competition 82mm IPD Plenum requires the additional purchase of the 997 GT3 82mm TB.
Features:
  • Increases horsepower, torque, and boost responsibly optimizing air flow efficiency
  • Designed with 3D Modeling & Computational Fluid Dynamics software
  • Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow
  • High quality cast aluminum construction
  • Direct fit OEM replacement
  • Made in USA
BBi Autosport Porsche 987 Cayman StreetCup Suspension Components
BBi Street Cup Suspension Components Typically Share The Following Features:
  • Hard tested on the street and track
  • Provides additional adjustment range
  • Helps maintain proper suspension geometry
  • Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
  • Eliminates factory rubber bushings for improved suspension feedback
  • Direct bolt-On replacement and requires no modification to the vehicle
  • Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
  • Precision Teflon lined spherical rod ends for smooth operation and long life
  • Discrete black anodized finish for increased corrosion resistance
  • Made in USA
BBi Autosport Front & Rear Lower Billet Control Arm Kit
(shown with optional camber and litronic shims)
  • Improved two piece 996 GT3 lower control arm design
  • Stronger than cast motorsport Cup arms
  • Allows proper camber adjustment 996 & 997 Models
  • Uses GT3 shims to adjust camber & lower control arm length (sold separately)
  • High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
  • Sealed monoball inner bearing
  • Allows easy access to inner arm hardware
  • Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
  • A must have for all track and race enthusiast
  • Each kit includes pair of 2 arms
  • Fits both front and rear axles
  • Part Number BBILOWRCNTRL9697
BBi Autosport Front Bump Steer Kit
  • Helps eliminate bump steer by maintaining proper front end suspension Geometry
  • Utilizes misalignment rod ends of the arm to provide maximum articulation
  • Highly recommended for vehicles that have been lowered
  • Each kit includes pair of 2 Links
  • Part Number BBIBUMP9697FRONT
BBi Autosport Rear Adjustable Toe
  • Provides additional rear toe adjustment
  • OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
  • Helps maintain proper rear end suspension geometry
  • Part Number BBITOE9697REAR
BBi Autosport Front & Rear Thrust Arm
  • Connects the Lower Control Arm to the subframe
  • Provides precision caster adjustability
  • Spacers included for setting stock or anti-squat and anti-dive configurations
  • Each Kit Includes Pair of 2 Links
  • Part Number BBITHRUST9697
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
  • Provides two eccentric mounting points
  • Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
  • A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
  • Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
  • Complete set of 4 (2 front & 2 rear)
  • Part Number BBITHRUSTBUSH9697
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Quick Reply: BBi Autosport Black Friday Sale 987 Boxter Cayman Suspension & IPD Plenums
