Winter
Winter
Took delivery of a 2013 Boxster this year, plan to put it away for the winter, and need some tips. I got the Porsche battery maintainer, but need advice on the rest of the drill. Tire pressures, moving the car from time to time....etc. Advice would be appreciated. Thanks.
I store my 2007 for 5 months each year. I increase the tire pressure 50 psi, fill the tank with non-oxy fuel and add stable. I also clean and treat the leather and change the oil but since yours is new doubt that is necessary. The place I store it maintains 45 to 50 degrees and is dry and clean. They throw the cover on and disconnect the battery as maintainers are not allowed. The cover is a covercraft dustop which is available many places on the web. The car is not moved during storage which has not been a problem in the past 5 winters.
I really like the new Boxster. Drove one on an autocross course last summer during a Porsche test drive event. Even though the Boxster S I have is a great car the 2013 is even better.
I also make a point to change the oil before storage.
By the way, living near the coast I would make an effort to keep the car stored somewhere dry and possibly use a dessicant inside the car to keep the moisture to a minimum. I also would not start the car at all during storage. Starting and moving the car won't help, it will only increase the wear/tear on the engine and exhaust..
Don't start the car, unless you can get it up to running temperature. If you are just leaving it in idle, it doesnt really get warmed up.
I do at that were mentioned. Plus, mothballs, or any rodent repellants.
Winter is No Fun!
This is my first winter storage, and I went to a PCA Tech Session on winter storage at a local indie.
In addition to everything mentioned, a popular subject for discussion at the Session was rodent-proofing the car. I had a problem with chipmunks during the driving season, so this is a concern for me.
What I am doing to make sure mice don't move into my car:
1. Mouse traps with peanut butter surrounding the car as my first line of defense. Think of them as being nut-flavored Claymore Mines.
2. A product called Mouse Magic, which are teabags filled with Spearmint Oil, Peppermint oil, and Fuller's Earth. They will be placed on top of each tire, and inside each tailpipe. These are my teargas dispensers.
Better living through modern chemicals.
As to why I keep in storage for 5 months..Minnesota. Usually it is closer to 6 months as April is pot hole season so until they are fixed and the roads cleaned I tend to leave in storage. I usually put in storage by 11/1 since the weather can turn quickly causing salt to be used.
2. A product called Mouse Magic, which are plastic teabags filled with Spearmint Oil, Peppermint oil, and Fuller's Earth. They will be placed on top of each tire, and inside each tailpipe. These are my teargas dispensers.
But putting any in the tailpipe is of no use. I've never seen mice gnaw converters.
Mice (and other creatures) like the same parts of the car as you do: The cabin. Not to live but to use it a big box store for housing/bedding materials. They'll nest on top of the engine. So put a Mouse Magic on top of the engine. Put two.
If you can put some in the cabin, in the radiator ducts, and a few on top of the under body panels. A favorite mouse highway is the top of the panels under the center of the car with the small tunnel above.
Put some in each trunk too. In the rear trunk put one in each rear corner near the vent covers that let cabin air exhaust to the the outside. Behind those vents are soft rubber flaps that seal against air flowing into the cabin but open to let air vent from the cabin. Mice can go through those rubber vents without even having to chew their way.
It may seem overkill but put one on top of or as near to the engine air intake filter and cabin air filter as you can.
If these Mouse Magic things have an expiration date be sure you renew them on or before they expire. You want the stuff active and high strength.
Also, do not store the car and forget about it. Check it once a week for signs of rodent infestation. Primarily this sign will be litter (or worse) on top of the plastic under body panels.
Last needless to say keep track of where you put what and be sure to remove all before you start the engine in the spring.
Porsche Nut
I would only drive it once or twice a week but at least I got to drive it a little.
Being in Hull, you have a good chance of getting more rain than snow compared to the towns more inland.
Thanks, Charlie C. I think that's what I will do as well. When you did have the car sitting idle waiting for dry clean roads, did you also over inflate the tires or just do the battery maintainer?
