How do you reset the service light?
Old 10-27-2017, 08:33 PM
  #31
longhorntodd
7th Gear
longhorntodd's Avatar
Yes, the Durametric Enthusiast works with my 981 Spyder. Although, it IDs the DME as a 991 on the 3.8 ltr
Old 10-27-2017, 09:29 PM
  #32
MrMoose
MrMoose's Avatar
Originally Posted by terbiumactivated
Never had to pull the fuse on my 987.2 with the durametric and I'm grateful I have not. Mr Moose what did you have to do reset it and pull the fuse to break the circuit then simply replace it? Can you share which number fuse it was, I'd like to make a note in case one of my future resets includes the same procedure.
I did the service reset in Durametric and it didn’t clear. Then I pulled the cluster fuse for 30 sec and it cleared. This happens every time I do the service reset. It’s a 2010 Cayman S.
I’m not in front of the car right now, but I used the guide in the fuse box to tell me which fuse to pull. There was a note in the Durametric software that indicated that this might be necessary for some cars.
Old 10-27-2017, 10:21 PM
  #33
terbiumactivated
terbiumactivated's Avatar
Copy that thanks, since mine worked I assume it's going to again.
Old 10-28-2017, 01:07 PM
  #34
skuplist
skuplist's Avatar
What year would that version 991 be? 2015? My friends shop has a computer for Porsche but we kept trying Boxter options which did not work.
Old 05-06-2019, 12:00 PM
  #35
gman3280
gman3280's Avatar
Had the "service now" message pop up on my 987.2. I have the Durametric, Where specifically should I go to reset this? Thanks!
Quick Reply: How do you reset the service light?
