RS 60 rear window
RS 60 rear window
below is an excerpt from an article on the new RS - it suggests the rear window is larger than the normal boxster. has anyone else read or noticed? mine is now in storage so can;t check?
"As you continue your walk around, the exterior of the car appears unchanged, but my local Porsche PR representative pointed out that the soft-top’s rear window is slightly larger than that of other Boxster models. This is probably a sign of things to come and gives the car’s passenger compartment a less claustrophobic feel than in the past. As a larger individual, I see these as a big improvement"
