Headlight Delamination - How bad is this one?
How bad would the board here consider this? Worthy of a CPO? If beyond CPO how much would it affect the value in negotiations?
Asking for a friend.
I'm guessing you're trying to buy this car? If it's a CPO, they'll just replace the headlight. Mine looked similar and I just had mine replaced last month under CPO...
Doesn't look bad, but I had one very similar and it was replaced under warranty. Mine was a PDLS version, so looking up the price of the part(s) shows a MSRP of around $1900/each. According to the dealer, there is more labor involved than "typical" in that the light needs to be calibrated/aligned with the PIWIS tool after installation.
It is out of warranty. Know it is crazy expensive to replace. Trying to figure out a fair dollar amount to attribute to it. Car has less than 20k miles and is otherwise very nice.
If the parts alone are $1,900 add labor and you're at approx $3k. Other option is to source a used replacement in good condition and include it with the sale of your car at no charge. Maybe that saves you $1,000-1,500.
How much better can one get? Is finding a replacement just finding one that hasn't yet started ?
Note there are at least four headlights, a halogen (cheapest) and three Xenons. One has fixed aim, the other two differ cosmetically with one with more black around the lights. The last two are the expensive ones, and I found an on-line dealer price about $1500. If replaced, you need to re-aim the light. If you are happy with the current light's aim then pull your car near a garage door and mark the beam location (horizontal and vertical) on the door with tape. Install the new light and adjust to match. Under the hood, behind the toolkit and tire sealant are two plugs. The upper plug controls the vertical and the one below and forward controls horizontal position. You need to adjust with lights and ignition on and then turn light off and then ignition off. Turn back on to ensure the settings are memorized and repeat if not. If I remember correctly, the alignment tool needed is a 5 inch long 5mm allen wrench with a ball end.
The other side light is still perfect. So who knows why one side goes bad and the other does not.
V6
Based on your pic, if all else was good on the car I wouldnt let it kill a deal.. Like I said, mine was worse and I wasnt even inclined to mention it until the SA said to check it.. Use it as a negotiation tool.
Pretty sure my buddy closed on the deal. The light is PDLS. They negotiated a few hundred more off what they agreed on. Echoing what Saabin said, if the dealer didnt point it out, and the car was delivered, would he have noticed it? Probably not. The rest of the car looked right in the pictures I requested. A few of us overly analyzed the pictures. I dont think he will regret the purchase. If the headlight starts to annoy him all he has to do is get in the car and push the "binocular" button; and drive. He will forget all about it.
When we were analyzing the pictures one of the analysts asked me why I'm not selling my 07 to buy this one. Easy - $$$! Otherwise I may have gone for it. I'll fill in the details when it is in his driveway.
Buddy bought the car and it was delivered late Thursday 14 CS manual. The headlight delamination is the only visible flaw I saw at night. I'll get a good look in a few weeks. He left for vacation. The black paint looked "right" under the lights which would have magnified any imperfection. The agate/pebble interior is immaculate, it has, PASM, binoculars and will turn 14,000 soon. Because the Porsche dealer was 200 miles one way and 300 miles the other way he didn't get an overrev report or PPI. But we did get pictures of the control arms and the factory paper bar code stickers on the control arms etc. He traded his 13 Panamerica 4S with 30,000 miles. He took a gamble, it was a calculated risk and I think he did well on this car. The only damage/wear is the headlights. There are no chips or sandblasts in the lights, just the delamination. The local Porsche store will pull an overrev report when he gets the oil changed and they do a once over.
