Anyone here using the Rennline GT3 Bumper Vent?
I'm going to be installing a center radiator on my '07 Cayman S, and figured that while I have the bumper off I could install a GT3 Smile vent. Just curious if anyone here is using the kit from Rennline. I read some reviews and watched their install video, seems pretty straight forward. They offer a template for the cutout for $75, but not sure if it's really necessary. Any feedback would be much appreciated,.
For reference, here is the Rennline kit. http://www.rennline.com/Rennline-GT3...oductinfo/E9X/
I'm not sure I can answer your question completely but I do want to add to the discussion. I installed the center radiator on my 2006 Cayman S. The install was much easier than I expected and there are some good YouTube videos that show step by step procedures.
The radiator comes with a faring that mounts to the back. This faring directs the outgoing air "down" and you have to cut corresponding holes in the bottom of your bumper for the air to exit. This faring cannot be mounted in the reverse to have exiting air flow upwards (i.e., to the exit holes provided with the GT3 grill).
I'm guessing that the real GT3 center radiator has a faring that directs the air upwards and I would think to use the GT3 grill, in a functioning mannor, you would need this faring. Otherwise, the GT3 grill on a Cayman is just for looks.
I'm anxious to hear from anyone that has experience with this.
One more piece of advice: The center radiator for the 987.1 does not have a grill in front of the radiator. It's just an opening however, it does have a rubber housing that mounts to the back side of the bumper that connects the bumper to the radiator and gives it a clean, functioning look. I wanted to have a grill that matched the grills on the fog light/radiator opening and so I ordered the center grill that is made for the Cayman R - It does not fit. The shape is a little different. I even tried to make it work by cutting out the grill part from the Cayman R and was going to glue to the opening that comes with the radiator kit but that won't work either - the measurements just won't work. Just FYI.
Thanks for the feedback about the radiator! From what I've read the GT3 vent is supposed to allow the incoming air though the bumper an easier path of exit, which in turn increases down force. Would be like to hear other peoples take on that.
I have a friend that has a GT3 and I am going to take a look at how that exit air is routed. I won't be able see his car for a couple of weeks though.
$75 for a template?!?!
My whole vent only cost me $75 on ebay.
Install is easy, traced it with a dry erase marker for my cut line, and it took less than an hour. Though I'd advise cutting while the bumper is still on the car, so it's not flexing in any weird way. Then clean up your mess and secure the vent in place with the bumper off. The trick is to cut smaller than you think you need and use a dremel to sand down any edges until the grille fits nicely in place.
More info here: https://rennlist.com/forums/987-981-...l#post15550642
Added the same mesh that I have been using.
http://www.autoatlanta.com/porsche-p...section=802-00
There are a few threads with loaner GT3 smile templates going around. I've got one that I picked up for my 986 Boxster but I never installed it (would require some trimming) but now that I have a 987 Cayman I may install it if I go the 3rd radiator route, hoping to find a definitive DIY that covers venting, etc. I'll check out your thread!
The OEM Porsche part by itself is only around $40:
Though is the OEM part designed for aftermarket application, or is it designed to clip into the GT3 bumper?
Nice, thanks for sharing. Looks perfect! Did you buy an actual kit that included hardware to secure it to the bumper as well as a grill? I was looking at just the vent on Suncoast, but it does include hardware to secure it. If I do get the one from Rennline I'll exclude the template.
The grille was just some left over mesh I had from doing my radiator grilles. It's $2 black powder coated gutter guard mesh.
I honestly can't remember if it came with the hardware or not. I want to say it did not... I have boxes of nuts and bolts from other builds, so I haven't had to go to the hardware store in years.
I installed the rennline kit and I used the template. One thing I've learned over time is it's cheaper to buy the right tool for the job.
I'd be happy to lend you mine if I can remember where I put it.
Either way, use the template. It's worth the peace of mind and you'll be lamenting the $75 if the cutting tool (sawzall) gets away from you and you ruin the bumper cover.
Plus you don't have to worry about extra trimming afterwards with a dremel.
The rennline hardware kit is very nice but it looks like you can secure it without it, possibly by sandwiching the bumper between the smile bottom and the mesh. I'll see if i can post a pic of the underside of the vent.
Tidy is right though that factory design vents down anyway unless you use different ducting. I know NameTaken posted about someone using different ducting (or fabbing ducting) to vent up with the smile, but unless you do that it's not a functional piece IMO.
fnel1771 (07-31-2020)
